Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
Dr. Evil drilling holes in David's head.:scared:
Alternative:
If you have the hierarchy window open all the time like me. Just grab the hat and drag it and drop in on David's head listing.
Less painfull to David and you don't have to post work out the blood stains from drilling into his head:laugh:
You can use either method and parent figures and props to each other. Like glasses or bottles to a table you want to move. Figure like David to a seat in a car figure and then move the car. Another trick is if you load a table and then a bottle but the bottle loads on the ground...parent the bottle to the table, if the origin of the bottle is in the bottle (hopefully at the bottom) you can zero the X,Y, and Z translations in the bottle and it will be at the same orign on the table which if at the top of the table saves a ton of time moving things around. Even if the origns are not ideally set as explained, it should get the bottle very close to where it should be.
Gary
Poser won't put the hat on David's head for you. You have to do that yourself. But once it is where you want it to be:
Select Object -> Set Parent -> Select David's Head in the Hierarchy Window -> Click OK
Now the hat should stay on David's head until you take it off.
You can make the hat a smart prop from now on though if you resave it or save it and rename it. Then it should load on top of David's head.
Hi,
Poser 8.
I have a hat on my david figure but when I pose him, the hat doesn't cooperate and follow the position of the head. I've looked at Conform to when I have the hat selected, but the hat is a prop and doesn't show any options to conform to my guy's head. Must be simple solution. Any help out there?
