Sat, Oct 5, 6:14 AM CDT
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
Carrara Free Stuff here.
Subject: Leaves (test render)
Kixum ( ) posted Thu, 23 December 2010 at 3:30 AM · edited Fri, 26 July 2024 at 7:00 AM
I was looking at some of the other galleries and I was wondering if C could do good fall leaves.
Based on this test render, I believe it can!
-Kix
Hoofdcommissaris ( ) posted Thu, 23 December 2010 at 8:03 AM
Yes you can!
50parsecs ( ) posted Thu, 23 December 2010 at 1:21 PM
Looks great! I have to agree that you can.
ShawnDriscoll ( ) posted Fri, 24 December 2010 at 12:23 AM
Translucent?  Or no.  Was your gamma 1.8?  Or just 1?  Seems dark.
tkane18 ( ) posted Mon, 27 December 2010 at 8:58 AM
I tried that out too back in C6.
I was pretty pleased with the results.
Kixum ( ) posted Mon, 27 December 2010 at 11:34 AM
This render used translucency and some sub surface scattering.  No gamma.  I did jack up the light pretty high (around 200%).  You can see the translucency effect of the leaves on the tree trunks.
-Kix
UVDan ( ) posted Fri, 31 December 2010 at 1:32 AM
Forum Moderator
So that is all native Carrara veggies?
Kixum ( ) posted Fri, 31 December 2010 at 9:29 AM
Pretty much.  The trees that come with Carrara are pretty basic.  I did fuss with the textures a little bit.
-Kix
UVDan ( ) posted Fri, 31 December 2010 at 10:43 AM
Forum Moderator
I have noticed that the trunks and limbs are pretty basic, but if you cover them with leaves, they look pretty good.  I wonder of one could model the trunk and limbs in the vertex modeler and cover it with Carrara leaves?
Kixum ( ) posted Fri, 31 December 2010 at 9:06 PM
Actually the plant editor has a lot of magic in it which I have not explored but aim to.  I'm just starting to play around with outdoor stuff.
-Kix
ominousplay ( ) posted Tue, 04 January 2011 at 7:19 PM
I've played with surface object replication to achieve what UVDan has proposed.  It works well, you do need to identify the region that will take the leaves...
Never Give Up!
And very nice work Kixum.
Never Give Up!
Kixum ( ) posted Wed, 05 January 2011 at 5:42 AM
Thanks!
When I get done fooling around with Star desroyers, I want to try to work on some stuff for outdoor scenes and fall colors is a good one to start with.
-Kix
