Forum Moderators: RedPhantom
Hi Cyber Dream.
Thanks for your response. Where do you want me to change the angle? Is there any feature in Poser 8 available?
I have tried to smooth the egdes in a separate mesh editor. Made a copy of the blMilWom_v3.obj and tried the new obj in Poser. Unfortunately with no success.
Thrilling - Works fine in Poser 7.
Oddly enough I have found a copy of Victoria 3 in my Poser 8 library some minutes ago. I have made this copy of V3 in the past to get back all my settings of V3 with one click.
Okay - Primary I can continue with this copy but I'm curious why poser 8 is transforming some items like this way.
It's not "Smooth Polygons" - it's crease angle. You somehow changed the figure's settings, or you used an OBJ where all the vertices became unwelded.
Hi all.
think - the problem is a little bit tricky. Needless to say - I have done all the settings mentioned above. As I said - some items work - some not in the same session. At least - no problem in Poser 7.
Meanwhile I have found more items where this phenomenon is present. Most of them were added to previous poser versions.
I'm with bagginsbill and think the problem is based in the obj. Tomorrow I'm going to check two of these objects. Perhaps I'll find a clue.
Even very low poly models look better then this ???
Set Crease angle in the General Preferences, at 80 , the default, and you can go to 180 i believe. (I use the max setting for my Low Poly models).
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
This pic is just the imported obj file, not rendered.
Dev
"Do not drive
Where did you get the files you installed? From DAZ? If not, go download V3 from DAZ, if something like this is wrong then there is no telling what ELSE might be wrong with your download.
Hello.We are in trouble because the render of Victoria 3 is of poor results (see picture).
It seems to be the edges of the mesh have been creased.
I'm sure I have done the right settings in 'Render settings'. The display was set to 'texture shades'. Nevertheless the render and the display shows the same error.
More difficult is the result of other items like Victoria 4 or Mike 4. They both make renders without errors in the same session and same settings.
Does anybody knows whats' going on in Poser 8?
intel i7 930, 12GB Ram, ATI 5870 (driver 8.771.0.0)
MS-Windows 7, 64bit
Thanks in advance for your help.
