Sun, Nov 10, 8:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 8:20 am)
Subject: How do I reset hidden variable to 1 for empty morph channels on all body parts?
NightmareHero ( ) posted Mon, 10 January 2011 at 11:06 AM · edited Fri, 20 September 2024 at 8:33 AM
I did some custom geometery for SP3 and I re-rigged the obj file, when I did that it showed all the morph channels, even the ones that don't have any deltas. My question is, is there a script that hides empty morph channels by resetting the morph channel hidden variable to 1 again? Is there one for free that does this?
markschum ( ) posted Mon, 10 January 2011 at 3:06 PM · edited Mon, 10 January 2011 at 3:08 PM
file_463886.txt
either edit the cr2 using wordpad or similar and find the morph channel and change hidden 0 to hidden 1 ,
or heres a script
set morphs with 0 deltas hidden
import  poser
scn = poser.Scene()
fig = scn.CurrentFigure()
acts = fig.Actors()
for act in acts:
    print act.Name()
    parms = act.Parameters()
    if parms:
        for parm in parms:
            if parm.IsMorphTarget() and (parm.Hidden() == 0):
                d1 = parm.MorphTargetDelta(0)
                if d1:
                    parm.SetHidden(1)
                    print "Hiding  -  " + parm.Name()
 print "Done"
there may be a better way, this tests for a parameter dial that is not already hidden and which is a morphtarget , looks for a delta and if there isnt one it hides the dial.
This only works on the copy in memory , so you have to save the figure back to the library. I suggest saving it with a new name until you are sure its worked correctly.
The script lists each body part as it runs , and lists "Hiding - parameter name" if it hides a dial.
It works on the current selected figure.
copy of the script attached, rename ot ftom .txt to .py
