Sun, Feb 9, 4:17 AM CST
Subject: Poser 7 Material Room
ladyperiwinkle ( ) posted Wed, 19 January 2011 at 1:43 PM · edited Sun, 09 February 2025 at 4:16 AM
I know how to import jpegs in the material room, but how do I get bigger or small size patterns -- sometimes they are way to big for something. Then how would I add save it to keep it in the material room so that i will always have it.
Thank you
bagginsbill ( ) posted Wed, 19 January 2011 at 2:01 PM
On the Image_Map node, adjust U_Scale and V_Scale. To keep the same aspect ratio, the two should be kept the same. I find it handy to use a node for the scale. Create a Math node and plug it into both. Use the number in the math node to be the scale.
bagginsbill ( ) posted Wed, 19 January 2011 at 2:04 PM · edited Wed, 19 January 2011 at 2:06 PM
ladyperiwinkle ( ) posted Wed, 19 January 2011 at 2:27 PM
how do I create a math node?
bagginsbill ( ) posted Thu, 20 January 2011 at 6:35 AM
Advanced Materials
Options menu
New Node
bagginsbill ( ) posted Thu, 20 January 2011 at 6:36 AM
Linking the new node.
Nodes have categories.
bagginsbill ( ) posted Thu, 20 January 2011 at 6:37 AM
Math nodes are in category Math.
The Math node has many subtypes.
hobepaintball ( ) posted Thu, 20 January 2011 at 7:20 AM
Another gem from BB. And an easy to follow and understand one too.
ladyperiwinkle ( ) posted Thu, 20 January 2011 at 10:30 AM
Good heavens -- I hope I can do it -- I am a hands on person, if someone was next to me  and i watched them do it -- I'd pick it right up -- But reading the directions and doing it at the same time  -- I am like a monkey.
Thank you for the info --- I will give it a good try when I ahve the time to sit down here over the next few days
hobepaintball ( ) posted Thu, 20 January 2011 at 11:36 AM
Quote - Good heavens -- I hope I can do it -- I am a hands on person, if someone was next to me  and i watched them do it -- I'd pick it right up -- But reading the directions and doing it at the same time  -- I am like a monkey.
I find it easier to kill a few trees. Print this thread, and have it in your hand when you try it. Don't try split screen or tabbing back and fourth if you are a distracted learner. Many hands on people I have worked with like to keep anything except the task at hand as simple as possible and have the key strokes and flow go just like when they try it "by them selfs" later.
nruddock ( ) posted Thu, 20 January 2011 at 4:26 PM
Quote - I find it easier to kill a few trees. Print this thread, and have it in your hand when you try it.
If you're going to print something, you might as well do the whole manual ;)
