Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Thanks Phil
wow new avatar!
Phil , being a dummy and using notepad, how do i format that text to occupy separate lines ... i notice that little square thing in notepad - must be a line break indicator - this little square thingy appears after each piece of Poser generated data but I ned to get that line break into my added code
how do i get that same effect??
Thanks
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
notepad shows these line breaks ( little square indicator) and i knew i had a prob as i enetered my data - see , there are no line breaks for my 5 lines
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Do yourself a favor and switch to a serious CR2 editor (I recommend Dimension3D's Poser File Editor). This stuff is just way too easy to screw up with a plain text editor.
Try this:
targetGeom armpit_rCol
name armpit_rCol
initValue 0
hidden 0
forceLimits 1
min -10000
max 10000
trackingScale 0.02
keys
static 0
k 0 0
interpStyleLocked 0
valueOpDeltaAdd
Figure 2 <span style="color:#99cc00;">[must be consistant with number used in rest of figure]
</span> rCollar:2 <span style="color:#99cc00;">[must be consistant with number used in rest of figure]
</span> zRotate
deltaAddDelta -.5
Sometimes Notepad does not format the text correctly. Try using EditPad Lite, its free and a better editor. A cr2 editor can also be usefull (eg Poser File Editor, or the free CR2Builder).
Thanks for everyone's advice !
thanks yes markschum yes it was the simple sollution of the return key - it worked in basic notepad.
JCM works .. my first one I am psyched !
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
"rCollar:2 [must be consistant with number used in rest of figure]"
Les it still works without the number "2" here - is it important I add it?
Thanks
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
Hi there.
I am not even sure where the problem exists exactly
maybe my lines are written incorrectly - just not putting in the correct language??
maybe I am not properly editing and saving the CR2?
( i dont have a good CR2 editor)
or maybe i am getting the names of the figure master or slave wrong out of misunderstanding.
I have a saved figure - it loads in Poser and becomes named Figure 2 so i guess that is the figure name
This figure also has a morph for the rCollar - the morph target is called armpit_rCol.
in the CR2 of the figure i have added the text that is here in italics:
** name armpit_rCol**
** initValue 0**
** hidden 0**
** forceLimits 1**
** min -100000**
** max 100000**
** trackingScale 0.02**
** keys**
** static 0**
** k 0 0**
** interpStyleLocked 0**
*** ValueOpDeltaAdd Figure 2 rCollar zRotate deltaAddDelta -.5 * **
indexes 271
but I get no results -
please note i have entered the value of -.5 because it is the negative Z rotation that I want controlling the morph
I might add i am a novice at editing CR2 i am actually using notepad - is that a joke or should it work??
I wonder about that because there seems to be something wrong ..... as even when pasting here it does not seem formatted correctly ( ignoring the italics of course)
can anyone help me?
Thanks
S
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
