Fri, Jan 10, 10:16 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Trying to edit CR2 to slave a morph
santicor ( ) posted Fri, 21 January 2011 at 9:59 AM · edited Thu, 02 January 2025 at 2:19 AM
Hi  there.
I am not even  sure  where the problem  exists exactly
maybe my lines  are written  incorrectly - just  not putting in  the correct language??
maybe I am not properly editing and saving the CR2?
( i dont have a good  CR2 editor)
or  maybe i am getting the names of the figure master  or slave wrong  out of  misunderstanding.
I have a saved  figure -  it loads in  Poser and becomes  named  Figure 2  so  i  guess that  is the figure name
This figure also  has a morph for the rCollar -  the morph target  is called  armpit_rCol.
in the CR2 of the figure i have added the  text that  is here in  italics:
targetGeom armpit_rCol
**   name armpit_rCol**
**   initValue 0**
**   hidden 0**
**   forceLimits 1**
**   min -100000**
**   max 100000**
**   trackingScale 0.02**
**   keys**
**    static  0**
**    k  0  0**
**   interpStyleLocked 0**
*** ValueOpDeltaAdd   Figure 2    rCollar    zRotate    deltaAddDelta  -.5   *    **
indexes 271
but I get no  results -
please note i have entered the  value of  -.5  because it is the negative Z rotation that  I want controlling the morph
I might add i am  a novice at  editing CR2  i  am  actually using  notepad - is that  a joke or should it work??
I wonder about that because there seems to  be something wrong ..... as even  when  pasting here it does not seem  formatted  correctly ( ignoring the italics of course)
can  anyone help  me?
Thanks
S
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
 http://www.renderosity.com/homepage.php?page=3&userid=580115
PhilC ( ) posted Fri, 21 January 2011 at 10:07 AM
You have the ERC code on one line, it needs to be on five seperate lines.
santicor ( ) posted Fri, 21 January 2011 at 10:10 AM
Thanks Phil
wow new avatar!
Phil , being a dummy and using notepad,  how  do  i format that  text to  occupy separate lines  ... i notice that  little square thing in notepad  -  must be a line break  indicator -  this little square thingy  appears after each piece of Poser generated data  but I ned to  get that  line  break into  my added code
how do  i get that  same effect??
Thanks
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
santicor ( ) posted Fri, 21 January 2011 at 10:21 AM
top line in this screenshot
notepad shows these line breaks  ( little square indicator) and i knew i had a prob  as i enetered my data - see , there are no  line breaks for my 5  lines
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
markschum ( ) posted Fri, 21 January 2011 at 10:34 AM
I use wordpad , it seems to do better than notepad.
To put things on seperate lines just place the cursor at the end of the line and press Enter
Poser uses a Unix like end-of-line indicator and that sometimes gives problems wirh dos style text editors.
pjz99 ( ) posted Fri, 21 January 2011 at 10:40 AM
Do yourself a favor and switch to a serious CR2 editor (I recommend Dimension3D's Poser File Editor).  This stuff is just way too easy to screw up with a plain text editor.
My Freebies
heddheld ( ) posted Fri, 21 January 2011 at 10:48 AM
or if your on a budget try notepad++ its free  (or theres other free editors)
trying to work like that in notepad must be a nitemare
lesbentley ( ) posted Fri, 21 January 2011 at 11:13 AM · edited Fri, 21 January 2011 at 11:15 AM
Try this:
                        name armpit_rCol
                        initValue 0
                        hidden 0
                        forceLimits 1
                        min -10000
                        max 10000
                        trackingScale 0.02
                        keys
                                static  0
                                k  0  0
                        interpStyleLocked 0
                        valueOpDeltaAdd
                                Figure 2 <span style="color:#99cc00;">[must be consistant with number used in rest of figure]
</span>                         rCollar:2 <span style="color:#99cc00;">[must be consistant with number used in rest of figure]
</span>                         zRotate
                        deltaAddDelta  -.5
Sometimes Notepad does not format the text correctly. Try using EditPad Lite, its free and a better editor. A cr2 editor can also be usefull (eg Poser File Editor, or the free CR2Builder).
santicor ( ) posted Fri, 21 January 2011 at 11:18 AM
Thanks for everyone's advice !
thanks  yes markschum  yes it was the simple sollution of the return  key - it worked in  basic notepad.
JCM  works .. my  first  one  I am psyched !
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
lesbentley ( ) posted Fri, 21 January 2011 at 11:21 AM
P.S.
The code in my above post is double spaced, this is an artefact of "improvements" they made recently to the replay box. It should really be single spaced.
santicor ( ) posted Fri, 21 January 2011 at 11:40 AM
"rCollar:2 [must be consistant with number used in rest of figure]"
Les it still  works  without the number "2" here - is it important I add it?
Thanks
SHOOT.
Don't talk "
   - Tuco
Santicor's Gallery:
markschum ( ) posted Fri, 21 January 2011 at 10:31 PM
It is important that the number match up with the figure number , otherwise you can wind up responding to9 a different figure.
lesbentley ( ) posted Sat, 22 January 2011 at 6:51 AM
Yes, what markschum  said.
