Sun, Jan 19, 2:58 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 2:30 am)
Subject: Mirroring objects/props/cloths????
DarkElegance ( ) posted Fri, 21 January 2011 at 5:11 AM · edited Sun, 19 January 2025 at 12:37 AM
Is there a way(or rather a simply way) to mirror a prop or clothing item in poser 6?
If I remember correctly there seems to be a way to do it in DAZstudio but I do not recall a way in poser 6
(though there may be and I am too daft to know it >.<)
https://www.darkelegance.co.uk/
Commission Closed till 2025
PhilC ( ) posted Fri, 21 January 2011 at 5:20 AM
The Poser Tool Box has that feature.
http://www.philc.net/PoserToolBox.php
SamTherapy ( ) posted Fri, 21 January 2011 at 6:08 AM
Also can be done in Wings.
DarkElegance ( ) posted Fri, 21 January 2011 at 6:41 AM
Quote - The Poser Tool Box has that feature.
unfortunatly I cant afford that right now:S
DarkElegance ( ) posted Fri, 21 January 2011 at 6:42 AM
Quote - Also can be done in Wings.
was more looking to abe able to hopefully do it with in poser. Though I will look into wings.
lesbentley ( ) posted Fri, 21 January 2011 at 12:07 PM · edited Fri, 21 January 2011 at 12:09 PM
Quote - was more looking to be able to hopefully do it with in poser.
To mirror an object round its left right axis in Poser, you can try this. Set the xScale of the prop to 0.1 and and export it as an obj, with only "Include existing groups..." selected in the export options. Set the xScale back to 100%. Lode the obj you saved into the prop as a morph target, set the morph dial at a value of 2.0. Export the prop as an object again, using the same export option as last time, then import this latest obj into your Poser scene with only "Flip normals" selected in the import options. With a bit of luck this is now your mirrored object. I can't guarantee this will always work, but it has worked for me on a number of occasions. You asked for a "simple" way, and I don't know if you could call this simple, but it does seem to work.
raven ( ) posted Fri, 21 January 2011 at 1:15 PM
Attached Link: D3D's Content Mirror utility
Although not strictly *in* Poser, there's also Content Mirror by Dimension3D in the marketplace here too, which works on props, clothing, hair etc.
kawecki ( ) posted Sat, 22 January 2011 at 12:09 AM
The next version of PropViewer will have it. (I have this in other app for many years)
Stupidity also evolves!
ypvs ( ) posted Sat, 22 January 2011 at 11:29 AM
I'm sure I've mirrored props with a magnet. Make the MagZone huge eg 1000% to avoid distortions. Set X-axis scale to -100% (or was it -200% ?) Will need to export/import object and save as a prop.
Just tried it in Poser 8 but it won't scale below zero despite altering the Min Level settings :(
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
kawecki ( ) posted Sat, 22 January 2011 at 7:49 PM
To mirror an object is very simple, just change the sign of the x or y or z vertices coordinates and then invert the normals of the object.
DarkElegance ( ) posted Sat, 22 January 2011 at 8:27 PM
Thank you all for posting and helping. I really appreciate it. I am going to try the suggestions of changing the x,y and z
again Thank you so much for the advice^.^
