Carrara F.A.Q (Last Updated: 2024 Sep 29 9:32 am)
When the cursor is stuck on open hand, there is a workaround to get it working again: press space. Works well for me after streaming video causes the open hand to get stuck.
I don't know whether it will fix the was-just-left-minimized issue.
I had a couple of times when the menu options like save/open/close/etc. were grayed out and I could not save (using keyboard or anything else). So far it seems to have been just a couple of isolated incidents when my system was due for a reboot based on another app activity, but this could be a very serious issue if it comes back.
I want to point out that here we are half a year later and this problem still exsists. I've run into it in every iteration of Carrara since version 5. Each time I had to reboot.
I just ran into it again (I have the latest C8 Pro) and so I decided to search the forums here. Interesting that illkirch should mention the watch video part... I was just watching a bunch of Mark's tutorials... not streaming, but from a CD, but still.
Anyway, thanks for the space bar work-around, it seems to have solved the issue.
It's a bug which has been known for a LONG time (I think all the way back to C1). The latest manifestation of it is a little different. Obviously whatever memory clobbering is going on is now changed due to the latest 64 bit compile. So the most recent experience I've had with it is putting it into the mixing channel, hitting the grayscale button and then you're messed up. The button partially disappears and you can't switch it back. Other manifestations of it have been issues with he pattern of the wires not rendering correctly. I used wires in the pool edge for my render of all the smily faces swimming in the big pool and it never really worked correctly. In addition, other users have emailed me about it with similar problems. According to some, it's been reported at Daz but I haven't personally checked.
-Kix
Okay. This happened a few days back and I thought it was probably an isolated incident, but it happened again twice today and I am starting to get worried...
I was working on my current project, a simple scifi scene in C8 Pro, and I had to just let it sit for a while so I could have dinner etc. So I minimized it and left. A few hours later I restored it from the taskbar and was about to resume work on it. But... I immediately noticed that I could no longer access certain commands. Minor stuff like Save and Save as. that kind of thing. I also could not select anything from the sidebar icons. When I would hover my mouse over them, it changes to an open hand icon and would do nothing. I closed the program and restarted it and there was no change. Last time I had to reboot the system to get it working again. Has anyone else had this problem. I seem to still be able to save using the Kbd. shortcut but the mouse pointer is totally useless. About 90% of my menu and icon commands are like this and I can't insert modify or otherwise manipulate any of my scene elements.
