I too received the error message image or file size incorrect, yet my submission was 800 x 600 and file size 192KB with thumbnail 100 x 100 13.6KB.
I'm never sure what is required in the first upload image box - (file size 10MB max.) I submit the Bryce .br7 file, of 8.7MB, Is that correct?
As a writer, I control the lives of millions. Whole worlds can be destroyed by typing the correct sequence of letters on my keyboard.
Robert A. Read
@ Phil: Your file came through over scale @ 1274 x 705.
I cleared the buffer, you can re- upload. The larger of either side needs to be 1024 or less.
Here is the text you submitted with your entry.
(Last Contact" - A race of being that can travel hundreds or thousands of light years would have no issue cracking the Earth like an egg.
Apart from the map of the earth this has no imports and no postwork.)
___
Ockham's razor- It's that simple
Quote - The jpeg actually gets laoded twice. Once in the image box and once in the file box.
No need for the BR-file.
Thanks for the info. In my defence, the file size of 10MB seems a bit misleading, jpegs being far smaller. The br7 file approaches that size, I assumed it was required to prove that the image was built up using Bryce.
Rob.
Robert A. Read
Sorry Rod, my upload should be in there somewhere. Forgot to resize the original, because I was rushing around.
http://joevinton.blogspot.com/
I'll clear the entry so you can resubmit. The thumb is heavy kb wise to.
Thanks for the heads up Joe.
Here is the text you submitted.
Man returns to the moon.
Just a quick one as I nearly forgot to get an entry in. Bryce with astronauts imported. Also post work on the earth to get rid of some edge details plus an improved star field.
___
**January 2011 Bryce Challenge
** ** "CONTACT"
ENTRY
Quote from Orbital:
the next theme will be called "Contact". With the on going search for life on other planets use Bryce to depict such a scenario. This can cover a wide range of topics, wether it be science fiction, or science fact. Maybe you want to use the movies for inspiration, wether it be an alien invasion, abduction, or something like Close encounters.
POST WORK
Anyway as usual I'd like to think you model as much as possible in Bryce. Imports are allowed as is postwork, but your final image should not be dominated by these factors.
Entry Page Link
___
