Fri, Jan 24, 5:51 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Request a Parent in mass script
grichter ( ) posted Mon, 27 December 2010 at 9:47 AM · edited Thu, 09 January 2025 at 7:12 AM
I searched this forum using the words parent and parenting and could not find what I was looking for, hence this request...(now if something already exists, please point me to where I can find it and sorry for the waste of pixels)
I spend a lot of time managing my scenes in the Hierarchy editor. When a scene starts to get to complex, I load a null figure and parent various figures and or actors that are set in the scene, so I can close the side arrow and collapse-shorten up the Hierarchy display. Which makes finding what I am working on currently a ton easier.
This is request is way way way beyond my scripting capabilities. Wonder if somebody could make a script that allows you to parent a group of figures or actors under a pre-selected null or any selected item. With an interface sort of like Semideu's Delete Multi script
First window you would select the parent to with check boxes like his Delete Multi. Second window you would select check boxes of the items you want to parent to the first selection.
If you try (smirk) to do complex scenes being able to 1 colaspse the hierarchy display down to the things you are currently working on or 2, being able to grab one item in the scene and move it and have everything parented to it follow along is a huge time saver.
I think the script would be complex enough, that it could become a sellable product.
TIA
Gary
Gary
PhilC ( ) posted Mon, 27 December 2010 at 9:53 AM · edited Mon, 27 December 2010 at 9:54 AM
Which version of Poser are you using?
And did you realize that you can drag/drop props/figures in the hierarchy window to define parents?
PhilC ( ) posted Mon, 27 December 2010 at 9:56 AM
i.e searching for an item in a Python multi line list box is going to be much the same work as doing the same in the hierarchy window.
grichter ( ) posted Mon, 27 December 2010 at 1:45 PM
Now at work and PoserPro2010 is across town. When you say drag and drop in the hierarchy window. I assume you mean in; not into. I drag and drop stuff all the time. But if you want to move 10-20 items and the list is long (from bottom to top)...on a Mac the window is very slow to scroll when dragging.
Gary
Dimension3D ( ) posted Sun, 06 February 2011 at 2:19 PM
My XO object manager can do this. It has a tree hierarchy similar to the hierarchy editor. It has a "parent" feature that parents all objects that are selected in the tree to the actor that is selected in the scene.
Dimension 3D - Poser Tools, Poser Props and Morphs, Cinema 4D Plugins, and more
Renderosity Store / D3D Web Site
grichter ( ) posted Mon, 07 February 2011 at 8:32 AM
Have to go back and explore that feature. Thanks for the reply
Gary
