Sun, Feb 9, 10:11 AM CST
Subject: is there a way to rotate a whole set of lights at once?
CMKook-24601 ( ) posted Thu, 10 February 2011 at 10:27 AM · edited Sun, 09 February 2025 at 9:08 AM
I set up some lights then realized afterward I want them all rotated about 180 degrees is there a way to rotate them all at once?
MagnusGreel ( ) posted Thu, 10 February 2011 at 10:32 AM
Parent them all to 1 object or light, then rotate that.
Airport security is a burden we must all shoulder. Do your part, and please grope yourself in advance.
CMKook-24601 ( ) posted Thu, 10 February 2011 at 10:33 AM
wow, that idea is so simple and ellegant I am ashamed I didn't think of that thank you very much
CMKook-24601 ( ) posted Thu, 10 February 2011 at 10:39 AM
okay edit I can't parent them with out pointing them at said object and I don't want to do that
LaurieA ( ) posted Thu, 10 February 2011 at 10:43 AM
note your settings and rotations before parenting. The act of parenting might point them at your object, but they can be pointed away again ;o).
markschum ( ) posted Thu, 10 February 2011 at 10:43 AM
point at and parent are two different things. You can parent them by drag and drop in hierarchy editor or by using the parent buttomn on the properties panel.
This method does not work correctly for infinite lights .
raven ( ) posted Thu, 10 February 2011 at 10:50 AM
Change an infinite light to a spot or point light, parent it and change it back. Voila, a parented infinite light.
CMKook-24601 ( ) posted Thu, 10 February 2011 at 11:00 AM
Quote - Change an infinite light to a spot or point light, parent it and change it back. Voila, a parented infinite light.
you sir are as badass as your sugestion thank you much :)
and thank you to every one for your help :)
Nance ( ) posted Fri, 11 February 2011 at 2:20 AM
This occurs so often, that I long ago set up my default scene so that it loads with all the lights already parented, & pointed at a dummy prop.   Too handy!
BionicRooster ( ) posted Fri, 11 February 2011 at 3:07 AM · edited Fri, 11 February 2011 at 3:07 AM
Forum Moderator
It's so simple, nobody ever thinks of the EASY way to do anything anymore lol
This is one tip i am sure to put in to affect ASAFP.
Poser 10
Octane Render
Wings 3D
