Wed, Jan 29, 9:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 8:42 pm)
Subject: how to delete full body morph?
trac ( ) posted Fri, 11 February 2011 at 6:55 PM · edited Wed, 29 January 2025 at 9:48 PM
hi there,
hopefully this is a stupid question!
I've created a full body morph using P2010 'create a full body morph' features... now I want to remove it again... I can't find an option to do so? Any help would be appreciated
corinthianscori ( ) posted Fri, 11 February 2011 at 7:34 PM
If you have Poser open, try looking for the dial that turns your FBM on and off. Usually just right-click the dial and select delete. Although...you have to do that in all your body parts. Dunno...Im in Poser 6.
trac ( ) posted Fri, 11 February 2011 at 9:23 PM
I've tried that, however the delete option is unavailable for the body morph or bordy part morphs it creates? Anybody done this?
corinthianscori ( ) posted Fri, 11 February 2011 at 10:02 PM
Quote - I've tried that, however the delete option is unavailable for the body morph or bordy part morphs it creates? Anybody done this?
Well,, there's always these free utilities that work like a charm! I'd try for Morph Manager. Its the simplest and fastest to use.
http://www.morphography.uk.vu/dlutility.html
lesbentley ( ) posted Fri, 11 February 2011 at 10:07 PM
Quote - how to delete full body morph?
To delete an full body morph (FBM) channel/dial in the Body, you can sellect the channel in the Hierarchy Editor, then press the Delete key on your keyboard. You will need to use "Show all parameters" in the Hierarchy Editor in order to see the FBM channel.
corinthianscori ( ) posted Fri, 11 February 2011 at 11:25 PM
Quote - > Quote - how to delete full body morph?
Now THAT makes perfect sense. Didn't even occur to me. Ouch. S'what I get for staying up late!
trac ( ) posted Sat, 12 February 2011 at 1:59 AM
It works! Great. Thanks for the big help!
