Forum Moderators: RedPhantom
There is a Universal Pose feature built-in to P8 which can serve you for applying body poses. You can activate the feature in General Preferences and any pose that you save back into your library will become a universal pose. IIRC, using the double check folder in the library under the Poses Category will apply universal poses also. I have never tried it with expressions, so I couldn't say if that will work the same way.
You might want to look thru this topic. Cage wrote a script to do what you're asking about.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2677445&page=1
There is a way to convert V3 face expressions to V4 face expressions ?
I have the same problem with some M3 body poses wich doesen't work with M4
I'm using P8 and i only have V4 and all her morphs....
Many thanks....
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
