Attached Link: Poser's Lights Tutorial
Here's a tut for ya that might help.
It's an oldie but a goodie and may help explain how Poser's Lights work.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
cheers,
dr geep ... :o]
edited 10/5/2019
Attached Link: Fine Tuning Poser's Spotlights Tutorial
Enjoy !!! :biggrin:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I find the way Poser adds lights with a random colour and off center is annoying. I zerowed the the translations, and rotations of a spotlight, and set its colour to white. I then used Ctrl+C to Copy the data, and Pasted it (Ctrl+V) into a text file.
I can copy the text and paste it into a light to give me a zeroed white light. The same file should work on any type of light.
Quote - I find the way Poser adds lights with a random colour and off center is annoying. I zerowed the the translations, and rotations of a spotlight, and set its colour to white. I then used Ctrl+C to Copy the data, and Pasted it (Ctrl+V) into a text file.
That's one way, but not as convenient as how I do it.
I make a light configured how I want. I save it to the library. Later, I load as many of these as I want using the "Add preset to current scene" button. This leaves the existing lights and adds what I want. I never use Poser's "Add a light".
I have saved all my favorite individual lights, such as my favorite sun, as well as multi-spot setups, several rims for add-ons, etc.
Quote - "Add preset to current scene" button.
P6 (grumble, grumble), must update (grumble grumble).
Same here, Les. :(
Here are the default Point and Spot lights I made for myself. They will load with Inverse Square attenuation into the middle of the scene at about head-height. They're intended for P8 / PP2010. I've changed the way they preview so they're easier to see and find.
Save the file above to your PC and change the .txt extension to .zip. Then extract to where you want (into a Lights folder).
Load these default lights by selecting them in the library and clicking on the Double Tick: any other method will cause all other lights in the scene to be deleted.
PoserPro 11 - Units: Metres
Adobe CC 2017
I'm having a devil of a time - and wasting a lot of time - trying to position lights with the Poser 8 Light Controls. One thing that would help is if I could determine, when moving the lights, which direction is x, y and z when I try to rotate them. Can anyone give me tips you use to position lights to get them where you want them?
And why can't you move the light closer and are only able to rotate them?
