Fri, Nov 22, 1:09 PM CST
Subject: Poser Polygon Count
Cybertenko ( ) posted Fri, 25 February 2011 at 11:22 AM · edited Thu, 21 November 2024 at 8:00 AM
Is inside of poser somewhere information about polygoun count of the scene?
jonnybode ( ) posted Fri, 25 February 2011 at 12:36 PM
Hi!
There is a python script called "printGeomStats" that will do the trick, it resides in folder "Printinfo".
Medzinatar ( ) posted Fri, 25 February 2011 at 12:40 PM
Top Bar "Scripts-->PrintInfo-->printGeomStats"
Cybertenko ( ) posted Fri, 25 February 2011 at 1:20 PM
thank you, can somehow be shown total polygon count? I am getting info about each object only.
geep ( ) posted Fri, 25 February 2011 at 2:53 PM · edited Fri, 25 February 2011 at 2:54 PM
  1. Export all objects
  2. Import (Exported) object
  3. Run script on imported object
cheers,
dr geep ... :o]
edited 10/5/2019
Cybertenko ( ) posted Fri, 25 February 2011 at 3:05 PM
a little bit complicated but i will try that. thank you.
RobynsVeil ( ) posted Fri, 25 February 2011 at 4:59 PM
Or, you can just add the results of printGeomStats? :biggrin:
Metaphor of Chooks
KageRyu ( ) posted Sun, 27 February 2011 at 2:58 AM
I believe the Advanced Render Settings from RDNA/Semideui will give the information you seek in it's main settings window.  It has a lot of other handy and useful abilities too - I consider it a must have.
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
