Sun, Nov 3, 5:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 03 10:43 am)
Subject: Heres a tricky one for you
Fugazi1968 ( ) posted Tue, 01 March 2011 at 1:56 PM · edited Mon, 28 October 2024 at 1:23 AM
What, if any, UVMap template does a point light use?
I have some point lights set up, with some procedurals to add colo(u)r to the light, which projects nicely out from the light itself (as you would expect).  What I would like to do it use an image map to project a variety of things, flames, caustics and all manner of stuff.
If any one has a clue as to the UVMap Template for a point light, or even a spotlight, I would me most grateful.
John.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Winterclaw ( ) posted Tue, 01 March 2011 at 2:25 PM
Point lights use a UV template?  I was under the impression that they don't.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Fugazi1968 ( ) posted Tue, 01 March 2011 at 2:27 PM
Tis an assumption, since it will take and project a procedural texture, I would think that it has some sort of uv information included.
Hopefully :)
John
Miss Nancy ( ) posted Tue, 01 March 2011 at 2:54 PM · edited Tue, 01 March 2011 at 2:59 PM
when texmap is applied to poser lite diff channel, it causes posersurfaces illum. by lite to exhibit perspective mapping according to the distance and orientation of lite.  analogous to the "perspective UVs" function in poser (camera mapping).  i.e., lite is projecting  map onto  posersurface.  intent is to map lite to produce a gel effect, but result is to cause posersurfaces to have multiplied perspective texture.  like slide projectors they useta put kodachromes in, before film went extinct.
hence a point lite with texmap becomes a 360 deg. texture projector. it might take an equirectangular texture o.k., but of course the idea behind the latter is to use it on surface of sphere to illuminate what's inside sphere.
Winterclaw ( ) posted Tue, 01 March 2011 at 2:57 PM
Okay, I did the most logical thing:  I made some test renders.
This is the U cordinate node
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 2:59 PM
Here's V, I've noticed that the black part gets lower the closer the point light is to the square.
WARK!
Fugazi1968 ( ) posted Tue, 01 March 2011 at 3:01 PM
Quote - Okay, I did the most logical thing:  I made some test renders.
Forgive my lack of understanding :) but how did ya do that?
John
Fugazi1968 ( ) posted Tue, 01 March 2011 at 3:03 PM
Quote - when texmap is applied to poser lite diff channel, it causes posersurfaces illum. by lite to exhibit perspective mapping according to the distance and orientation of lite.  analogous to the "perspective UVs" function in poser (camera mapping).  i.e., lite is projecting  map onto  posersurface.  intent is to map lite to produce a gel effect, but result is to cause posersurfaces to have multiplied perspective texture.  like slide projectors they useta put kodachromes in, before film went extinct.
I think it's going to take me some time to grasp that :)  Square map right?
Winterclaw ( ) posted Tue, 01 March 2011 at 3:04 PM
And here's tile.  Where the light is seems to change how the tiles look a little, but the plane it reaches out to remains the same.
Of course these were done against a square and not an inverted sphere.  I'm tempted to say there's some procedural method that determines how the light looks and not a map, but I need a little more info.
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 3:33 PM
Quote - Forgive my lack of understanding :) but how did ya do that?
John
I plugged the U cord into the light and I put the light at 1.000 zTrans while a simple square was at -1.  Move it further away and it'll start to look more normal.  I'm really tempted to say right now that the output of the light is more a function of angle and distance between the light, the object, and the viewer more than anything else.
WARK!
Fugazi1968 ( ) posted Tue, 01 March 2011 at 4:34 PM
Quote - > Quote - Forgive my lack of understanding :) but how did ya do that?
John
Thanks for that, while I'm not 100% sure I comprehend completely I think with some experimentation I'll get there.  Thanks for lighting the way Winterclaw :)
John
bagginsbill ( ) posted Tue, 01 March 2011 at 4:58 PM · edited Tue, 01 March 2011 at 4:59 PM
I have never tried UV on a point light! I am learning new stuff.
I know on a spot light it's a circumscribed square, where the corners do not get involved. If we consider a circle in the UV space, I know that radius = 0 corresponds with the exact point line at the center of the light cone, and radius = .5 corresponds with the edge of the light cone. I can't remember which direction is "up" - it depends on the orientation of the light if I recall correctly.
The exact ratio of cone angle versus UV radius is unclear to me. It's not linear. What I mean by that is that if you consider a UV circle at radius = .25, this is not half the cone angle. I was trying to figure this out in detail a few months ago because I was building a Python script that could generate a Poser spotlight that produced the correct distribution specified in an IES light. Through various experiments I got really close, but not exact. One of the problems I had is that if you try to make a spotlight with a 180 degree cone, it fails.
seachnasaigh ( ) posted Tue, 01 March 2011 at 5:45 PM · edited Tue, 01 March 2011 at 5:49 PM
@ Winterclaw:  regarding the first two images, it looks like perhaps U is out of phase from V, in the same way that sine is out of phase from cosine.  Same shape, different rotation?
I might have to experiment a bit with this.  But first, finish pizza...🤤
@BB:  Just offhand, I believe the Poser spotlight is limited to 160 degrees.  Unless you meant a hypothetical cone asymptotically approaching 180', in which case, never mind.😊
bagginsbill ( ) posted Tue, 01 March 2011 at 6:53 PM
The 160 degree limit is editable as with any property limit.
Once you set it to 180, you can try making a light that has a 180 degree cone. I found it possible to use 179, but not 180.
Winterclaw ( ) posted Tue, 01 March 2011 at 8:59 PM · edited Tue, 01 March 2011 at 9:00 PM
Okay, I created a basic color map as shown abpve.  Ztrans was at 5.
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 9:00 PM · edited Tue, 01 March 2011 at 9:01 PM
I moved it out to 10.
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 9:01 PM
This is ztrans equal 15.
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 9:02 PM
So I'm wondering why I'm not seeing the bottom half of the picture (tiling was turned off on purpose), so I moved it to z=5, y=10.  Still no bottom.
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 9:03 PM
And look what happens when I turn tiling on for the image map.
WARK!
Winterclaw ( ) posted Tue, 01 March 2011 at 9:07 PM · edited Tue, 01 March 2011 at 9:07 PM
And lookie what happens if I move everything below the ground plane.  The missing stuff is closer to top.  So the only thing I can gather from all of this is the middle of the image map is on the ground plane of poser when using a point light.
WARK!
Fugazi1968 ( ) posted Wed, 02 March 2011 at 3:16 AM
Thanks to everyone for your input, it seems like a much harder question than I had first anticipated :)
I thought that it may have a spherical map on it that could be used, but it looks more complex than that.
Though from BBills post it at least looks like some experimentation with a cluster of spolights might do the job :)
Special thanks to Winterclaw for his experimentation and renders, I think I might even understand those.
John.
