Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 23 12:07 pm)
It's a height map, like a bump or displacement map. I'm sure someone who knows more than me will give you the technical details :).
They have not been used in Poser for very long, as far as I know only Poser Pro 2010 can use them properly.
They are used alot in games to give details to a model.
John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Cool thanks. hmmm...I have poserpro2010, so If anybody can metion if there is any benefits of using this over or with the existing textering methods please spill the beans lol.
Bump and normal essentially are identical in terms of the outcome.
Bump is adjustable, normal is not. If you think being forced to adjust bump strength is a pain in the arse, then normal is better. If you think being not allowed to adjust bump strength is a pain in the arse, then bump is better.
Normal is a tiny bit faster than bump. On my machine, rendering around 500 thousand pixels of some surface, the normal mapped one will be 1 second less render time.
The Gradient Bump and then use the pull-down to activate Normal Map tangent space.
Quote - What channel do you attach a Normal to in PP2010? The bump channel?
PS - Who's Norma and why does she need a Map? (I couldn't resist!) :tt2:
You plug it into the gradientbump channel, then switch mode to Normal (whichever Normal type map you are using). As I remember the options are Tangent Space or Object Space (might be World Space), depending on the type of Normal Map you have generated.
John
PS. Norma needs a map because she is the long lost continent formerly known as Pangea, now found to be named Norma after some complicated pictograms were decrypted from some wall somewhere.
I'm using crazybump demo. It creates a batch of bump, displacement, specular, normal etc from your imported image.
My Renderosity Store
