Mon, Oct 21, 5:25 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 5:20 pm)
Subject: need cloth help
Soulpainter ( ) posted Wed, 09 March 2011 at 10:53 AM · edited Fri, 18 October 2024 at 8:01 AM
working on an image of a cross and wanted to have some material draped over it (long flowing wrap draped from one side, hanging in the front and then flipped over the other side. been ages since i used max and not having much luck in poser's cloth room. any ideas or is there a cloth out there that is poseable that i could use?
thanks for the assistance
Medzinatar ( ) posted Wed, 09 March 2011 at 11:30 AM
The Poser Primitive, "Square Hi-Res", is very dense and intended for applications like that.  Try at least 30 frames and include "Ground" in the list of collision.
Soulpainter ( ) posted Wed, 09 March 2011 at 11:33 AM · edited Wed, 09 March 2011 at 11:35 AM
this is what I am looking at achieving. i have tried the hi res square but not sure how to pose it lol
image is from http://www.faithclipart.com/image/cross-clipart-for-advent.html a free faith based site for images
BionicRooster ( ) posted Wed, 09 March 2011 at 12:08 PM
Forum Moderator
Attached Link: Cloth Ribbon
I made a cylinder, deleted most of it, and kept the part that wrapped around the cross.
Ran the simulation, and this is what I came up with. The dynamic cloth settings I used should be in tact when the prop is loaded, but you may be able to adjust them to achieve a closer look to what you want.
Poser 10
Octane Render
Wings 3D
Kendra ( ) posted Wed, 09 March 2011 at 12:28 PM
Have you tried using the morphing tool and magnets?  You could position the hi res square around the top of the cross and then let the cloth room drop it down.
...... Kendra
Kendra ( ) posted Wed, 09 March 2011 at 12:56 PM
Here's a quicky using the hi res cloth and the morph tool.  No magnets though.
...... Kendra
Soulpainter ( ) posted Wed, 09 March 2011 at 1:05 PM
you all are AWESOME thank you so very much. I have been away from poser for so long I forgot my little tools n toys. time to start clicking again...and maybe read the directions for a brush up too!!
RedPhantom ( ) posted Wed, 09 March 2011 at 1:51 PM
Site Admin
This is weird. I was trying to make almost that same image. Couldn't get it done. Glad you asked. thanks
markschum ( ) posted Wed, 09 March 2011 at 10:48 PM
I would do this in two stages
  1. cross horizontal with cloth straight across the top bit
  2. run simulation until ends of cloth are down maybe 30-45 degrees
  3. Rotate cross and cloth together so cross is vertical.
  4. run new simulation from that point to complete the drapeing.
Soulpainter ( ) posted Thu, 10 March 2011 at 8:02 AM · edited Thu, 10 March 2011 at 8:06 AM
I would like to thank everyone so very much for the help. Here is what I came up with. Bionicrooster, YOU ROCK!!!!! It worked great! I tweeked it just a little (made it a little wider but kept the length thesame)
BionicRooster ( ) posted Thu, 10 March 2011 at 10:39 AM
Forum Moderator
Very cool effect!    Gald I could be some help :o)
I messed around with the Y scale, and a lil more in the cloth room sim settings, and you can get it "thicker" with a few minor adjustments.
Main ones to adjust would be Stretch Damping, Shear Resistance, and Cloth Density. The 1st to numbers should go up(75-150), and the density should be around .0025
Poser 10
Octane Render
Wings 3D
