Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
image is from http://www.faithclipart.com/image/cross-clipart-for-advent.html a free faith based site for images
Attached Link: Cloth Ribbon
I made a cylinder, deleted most of it, and kept the part that wrapped around the cross.Ran the simulation, and this is what I came up with. The dynamic cloth settings I used should be in tact when the prop is loaded, but you may be able to adjust them to achieve a closer look to what you want.
Poser 10
Octane Render
Wings 3D
This is weird. I was trying to make almost that same image. Couldn't get it done. Glad you asked. thanks
Very cool effect! Gald I could be some help :o)
I messed around with the Y scale, and a lil more in the cloth room sim settings, and you can get it "thicker" with a few minor adjustments.
Main ones to adjust would be Stretch Damping, Shear Resistance, and Cloth Density. The 1st to numbers should go up(75-150), and the density should be around .0025
Poser 10
Octane Render
Wings 3D
working on an image of a cross and wanted to have some material draped over it (long flowing wrap draped from one side, hanging in the front and then flipped over the other side. been ages since i used max and not having much luck in poser's cloth room. any ideas or is there a cloth out there that is poseable that i could use?
thanks for the assistance
