Thu, Jan 9, 7:15 AM CST
Subject: Objects not rendering on the inside.
Fremmen ( ) posted Sat, 19 March 2011 at 8:46 PM · edited Wed, 08 January 2025 at 5:34 PM
Hello
I every once and awhile run into a problem where I render a picture and the inside of a cloth figure or a prop hair is for lack of better terms empty. For example I rendered a picture  from a forward view with a hair prop,  and between the right side of her face and hair that is next to it it came out just a white space(the back ground was white). The hair prop goes down to the neck. When I rendered it from the right side profile the hair is all the way down to  the neck of the person. Another time I rendered a picture from the front, of a hood on a figure, the inside of the hood next to the persons head was see-thru. Again from any view of the outside of the hood it is fine. Does anyone know what might be causing this. Thanks for any help in advance.
Simon
Medzinatar ( ) posted Sat, 19 March 2011 at 8:53 PM
select "Normals Forward" on material, that way they will face the camera
Fremmen ( ) posted Sat, 19 March 2011 at 9:29 PM
Thanks
 I will try that.
estherau ( ) posted Sun, 20 March 2011 at 1:30 AM
if you render with gamma make sure it is off for all your hair transmaps.
Love esther
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Sun, 20 March 2011 at 1:54 AM
nice!
estherau ( ) posted Sun, 20 March 2011 at 2:10 AM
that last post was in the wrong thread.  sorry.
lesbentley ( ) posted Sun, 20 March 2011 at 10:50 AM
Quote - I every once and awhile run into a problem where I render a picture and the inside of a cloth figure or a prop hair is for lack of better terms empty.
In your Render Settings, make sure "Remove backfacing polys" is turned off.
