Mon, Jan 13, 3:50 AM CST
Subject: Poser 4 to Bryce3D - What am I doing wrong?
NorleyS ( ) posted Fri, 17 August 2001 at 2:04 AM · edited Sat, 11 January 2025 at 10:59 AM
Help! Although I've followed some of the excellent tutorials posted here, I can't seem to get the textures mapping correctly in Bryce3D (rev 3.1, on a Mac). As you can see, I have the texture applied parametrically, but it still just wraps around entire figure. Does anyone know what stupid mistake I'm making?? Thanks.
kaom ( ) posted Fri, 17 August 2001 at 2:35 AM
Attached Link: http://www.awakemm.com/poserarcana/tutorials/rw/rw02/index.html
Go check out this site. It explains the whole process in detail,it's a very good place to learn your poser tricks. It will show you step by step how to do it correctly, and it's easy to follow. Good luck. kaom
NorleyS ( ) posted Fri, 17 August 2001 at 6:39 AM
Thanks for the hint. If only things were that easy!! I've gone through the tutorial step-by-step, but I still end up with the texture out of sync with the mesh (see Angel Fish picture). Any ideas??
ringbearer ( ) posted Fri, 17 August 2001 at 9:48 AM
Try rotating the map 180 on the x control in the material editor. Seems like I read that somewhere, but I don't remember where. Hope this helps.
There are a lot of things worse than dying, being afraid all the time would be one.
Phantast ( ) posted Fri, 17 August 2001 at 10:07 AM
It should. That's the problem.
ShadowWind ( ) posted Sat, 18 August 2001 at 12:01 AM
I had this problem when the texture wasn't square...1024x1024 or whatever...
NorleyS ( ) posted Sat, 18 August 2001 at 2:26 AM
Thanks everyone for the tips. Turning the texture through 180 degrees worked a treat! I wish I'd asked earlier and avoided many hours of frustration!!
