Thu, Oct 10, 12:16 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 09 12:13 pm)
Subject: Need a set? Coming soon only to renderosity...
lalverson ( ) posted Fri, 17 August 2001 at 10:52 AM ยท edited Sun, 04 August 2024 at 6:23 AM
Need a more rustic look? more Frontier? Want control of what part of a set you want? The Rustic kit is the Set you need. Each prop is seperatly materialed and allows you to set, change and color all the different parts, and the parts are easily named for fast changing. Also a fully detailed floor, with full under supports. This allows you to use the floor as a ceiling. Low polygon count allows for as much or as little of the kit you need/want to use. Here's what you get!! Files; pp2&png Log Wall Log Short window Log wall Short Log Wall Log window Wal Tudor Door Tudor Stop Tudor Stairs Textures all JPG brick1 STUCCO2a woodlt woods woodsn bronze Notes and tips; Each prop has material settings of Stuco, and Log, and frame. (except the door, it has more parts) Textures for each material can be changed in the material editor. If the wall sections are stacked one on top of another, like for a second story, changing the brick texture to stucco gives and excellent effect. allowing sections to collide with each other can also create some very interesting effects of longer walls, or higher walls, or wall with additional supports.
Fracture ( ) posted Fri, 17 August 2001 at 10:57 AM
Do you know if in the future you will offer any urban settings?
lalverson ( ) posted Fri, 17 August 2001 at 11:01 AM
Attached Link: http://www.n-link.com/~lalverson
The AFA prop department is currently doing some R&D of urban settings, there are some free building facades on my site. Please feel free to check thm out.
atthisstage ( ) posted Fri, 17 August 2001 at 11:33 AM
The Spankmaster 5000??? LOVE it!!!!!!
lalverson ( ) posted Fri, 17 August 2001 at 1:17 PM
Yeah, I was in silly mode when the prop department proposed that one. works pretty well i'm told.
Fracture ( ) posted Fri, 17 August 2001 at 1:21 PM
haha umm, eww.
robert.sharkey ( ) posted Sat, 18 August 2001 at 9:52 AM
Oh cool, one more of your fantastic Construction-kits. The textures looks really superb. SHARKEY
