Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:35 am)
You should take a look at the new Aikobot 2 at DAZ. It's amazing.
I agree. Best thing is you can use parts of V4 as you see fit.
Does that mean you can use any texture for V4 and just use limbs, or torso, or head from Aikobot, leaving the others with the human texture?
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
You can load the pieces you wanted. The set up allows you to load feet or arms or head or the torso on top of V4. You then conform those parts like you would clothing to V4. You can then turn off the V4 body part or leave it on. I applied the Aikobot head. and you get the helmet shown but also a new skin texture that I didn't like. I then applied my old face texture over it to get the picture above. You can use your own face morphs still as I did here.
You can also fit clothing over the Aikobot parts with a little work. I'm still working out some concepts here so the render is poor. The gloves do not come with the item, but I wanted to give her a certain look. Likewise the antenna loop is an item from RuntimeDNA. I added the high heels. Should give you some idea.
Good luck
A new definition of a Silicone Beauty... :biggrin:
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello everyone, I am working on a animation that requires a female and male robot and the from what I see online the shebot and hebot are the perfect look but I can not find them. Where can I get them... can I purchase them from someone? Thank you for your help in advance. Gina
