Vue F.A.Q (Last Updated: 2024 Sep 04 4:56 pm)
That update caused other problems for me, my screen kept breaking up after installing it, I had to roll back the driver to get it back to how it was. Each time the screen broke up I had to reboot by the reset button because it also stopped the mouse working and the Ctrl, Alt, Del didn't work either. One of their worst updates ever.
I did contact their support only to be advised to update my Bios and Mobo drivers, now I know what a world of pain that can lead to, so I didn't bother, the older version is just fine..
Injustice will be avenged.
Cofiwch Dryweryn.
Why on earth would they expect you to update your bios and mobo drivers? Surely their upgrades/updates should be backwards compatable?
The person that you contact via phone or email is never an actual computer tech. Just a filter. And their only job is to close tickets that they open.
Thanks Bruno I had already updated to that driver version and noticed the same problems. Just rolled back to the old driver and all is well.
roll, back, you can always update again when the next fix is out.
If everythign worked on the previous driver, and stuff didnt work with the new driver, theres no point in having the newest driver.
Rich
http://blog.richard-potter.co.uk
I've had that update since Beta with no problems, although I always delete the
old driver by using 'Driver Sweeper' and pick the option to do a clean install
of the new driver. I also save the last few versions of the drivers on an
external HDD in case I have to roll back.
Adriaan Barel (a.k.a. Vege
Mite)
"Morality, like art, means drawing a line someplace." --
Oscar Wilde
Quote - I've had that update since Beta with no problems, although I always delete the
Same here mate I delete the driver then run driver sweeper and install the last driver version. I save the last few driver versions myself :)
OpenGL is screwed inside Vue (9 and 9.5, didn't test earlier versions), any object not using texture maps is solid black in ortho views and solid brownish in camera/perspective views.
E-on is aware of the problem and is working on a fix. Xstream plugin inside C4D is not affected, dunno about other host apps.
