Tue, Nov 19, 7:21 PM CST
Subject: V4++ the leg twitch
devilfish36000 ( ) posted Sun, 24 April 2011 at 2:51 PM · edited Tue, 19 November 2024 at 7:12 PM
I have downloaded and installed the v4++ morphs, but when I try to use them, they dont work, and all I get is a weird twitch in the left leg
Any way of fixing this?
Thanking you in advance
kyhighlander59 ( ) posted Sun, 24 April 2011 at 3:34 PM
Hmmm I get the leg twitch but that means it loaded for me.
Victoria_Lee ( ) posted Sun, 24 April 2011 at 4:00 PM
The morphs are installed when you get the leg twitch (happens to most of us) and then you need to tweak the dials for the morphs you want.
Hugz from Phoenix, USA
Victoria
lkendall ( ) posted Sun, 24 April 2011 at 4:03 PM
For me, the twitch is ususally because inverse kenetics is on for the legs.
lmk
Probably edited for spelling, grammer, punctuation, or typos.
devilfish36000 ( ) posted Sun, 24 April 2011 at 4:12 PM
the dials dont seem to appear for the bosy, only the face
lkendall ( ) posted Sun, 24 April 2011 at 4:23 PM
devilfish36000:
Sorry if this is too elementary, and you already know this, but...
In the main preview window sellect your figure from the pull down menu on the right (the blue #1) and the bodypart from the second pull down menu (the blue #2).
lmk
lkendall ( ) posted Sun, 24 April 2011 at 4:27 PM
As shown here.
lmk
devilfish36000 ( ) posted Sun, 24 April 2011 at 4:29 PM
no such thing as too elementary, only got the thing yesterday.
thanks, that did the trick, strangely doesn't show these sliders when clicking on the body part
lkendall ( ) posted Sun, 24 April 2011 at 4:31 PM
You can also access the body parts for the currently sellected figure from the top of the property pannel.
lmk
lkendall ( ) posted Sun, 24 April 2011 at 4:32 PM · edited Sun, 24 April 2011 at 4:32 PM
As shown in this screen capture.
lmk
devilfish36000 ( ) posted Sun, 24 April 2011 at 5:20 PM
Now I cant seem to do more than one morph at a time
lkendall ( ) posted Sun, 24 April 2011 at 5:44 PM
devilfish36000:
What version of Poser are you using?
Do you mean that you can't load more than one morph at a time?
lmk
lkendall ( ) posted Sun, 24 April 2011 at 5:56 PM · edited Sun, 24 April 2011 at 5:57 PM
devilfish36000:
If you put your mouse pointer on a body part and click the right mouse botton (in Poser 8 and PoserPro2010) you will get a dialog box. Put the mouse pointer on the Select line and you will get a box of things to chose. Sometimes you might have to try several times until you see what you want in the selection choices. This is safer than clicking the left button, which can end up moving the figure, even when you do not mean to do so.
This may not work in earlier versions of Poser. I do not remember that, but some one else will.
lmk
devilfish36000 ( ) posted Mon, 25 April 2011 at 5:00 AM
Thanks for all the help, i've managed to muddle my way through it
SamTherapy ( ) posted Tue, 26 April 2011 at 3:42 AM
Did you initialize and update V4?  Weird things happen with it if you don't.
The leg twitch - as noted above - is perfectly normal.  The other things you mentioned aren't.
