Sat, Nov 9, 6:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
Subject: Reg Ibl lighting in poser 7
cfpage ( ) posted Fri, 29 April 2011 at 4:34 PM · edited Sun, 20 October 2024 at 4:02 AM
When you do the first render it comes out overly bright and is fine in the second render
how get around this if you set up to render multi. sceens over night ?
poser 7
bagginsbill ( ) posted Fri, 29 April 2011 at 8:26 PM
SR3?
cfpage ( ) posted Fri, 29 April 2011 at 11:20 PM
Quote - SR3?
SR3, yes
bagginsbill ( ) posted Sat, 30 April 2011 at 8:29 AM
I don't remember this bug, but what you described tickled enough of my memory to cause me to think I ran into it.
Does this 1st-render problem happen after loading a new scene or just after starting Poser?
How are you currently doing multiple unattended renders?
If it's a startup problem only, perhaps a script could be used to load and render multiple scenes without starting Poser over and over. But I suspect that's already what you are doing.
cfpage ( ) posted Sat, 30 April 2011 at 11:29 AM
typically I'll work on a project once Iam happy with it I save it close poser and re-start it for the render, because you know memory problems and such it gets buggy and heavy so a fresh re-start less problems. most time's I have 1 IBL. on the re-start and it comes out washed out.  what I do is make a tiny area render and then the full render no big deal.  Because the sceens are bigger and more complicated they take longer to render so why not get a script to render 2 or 3  at night but no point if I use Ibl
tested a sceen rendered with default poser lights then loaded a Ibl light set from libary
and its needs 2 renders, technically I guess it needs to  calculate Radiosity ?
does this happen in poser 8 or pro ?
