Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
It won't let the texture be part of the SSS calculation, but you can then mix a texture with what Carrara comes up with. So if you're trying to knock out portions of the SSS or change it in some way, you can use a texture. Very handy for putting that paper label on the outside of a candle kind of texturing problem. Attached is a sample image.
Click on the platform/version you need underneath the Try Shader Ops 2 to get the download you need.
Regards,
Eric Winemiller
Digital Carvers Guild
Carrara and LightWave
plug-ins
Quote - > Quote - Just a quick question - when using the Light Mangler, are you now able to use texture maps for SSS?
Also, when I click on 'Try Shader Ops 2' the button doesn't work.
Looks like a great plugin!
Regards,
Ok - thanks for the detailed response :) I'll give it a try :)
I added a tutorial for the Camera Mapping shader.
http://www.digitalcarversguild.com/tutorial.php?TutorialId=35
Regards,
Eric Winemiller
plug-ins
Hi folks,
We've just released Shader Ops 2. Shader Ops 2 is a new plug-in collection with powerful new lighting and shading tools; Camera Mapping, Light Mangler, Space Mangler, Multi Ops, and more.
Remix your shaders after the lighting is done with Light Mangler. Multi Ops and a new in channel Layers List simplify and enhance the shading tree. Camera Mapping opens new avenues for mixing in real world footage or photos. Space Mangler lets you map from one space to another. Blur, well, blurs child shaders. Crop UV can grab just a portion of a UV shader.
Check out the product page at
http://www.digitalcarversguild.com/plugin.php?ProductId=20
Below is an example of the Camera Mapping in action.
http://www.youtube.com/v/EENWtutaONE
You can download the demo from the links below.
Carrara 8.1 Windows 32-bit
http://www.digitalcarversguild.com/downloads/c8/shaderops2w32.zip
Windows 64-bit
http://www.digitalcarversguild.com/downloads/c8/shaderops2w64.zip
Mac OSX 10.5 or better
http://www.digitalcarversguild.com/downloads/c8/shaderops2ub.zip
Mac OSX 10.4
http://www.digitalcarversguild.com/downloads/c8/shaderops2ub104.zip
Carrara 7.2 PC
http://digitalcarversguild.com/downloads/c7/shaderops2.zip
Mac OSX
http://digitalcarversguild.com/downloads/c7/shaderops2ub.zip
Regards,
Eric Winemiller
Carrara and LightWave plug-ins
