Tue, Nov 26, 6:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Anybody got any pants rigging tips?
Fugazi1968 ( ) posted Thu, 05 May 2011 at 2:47 PM · edited Tue, 26 November 2024 at 6:01 AM
Hi Poser People
I got this pair o pants right, and try as I might I just cant get rid of that jagged edhe when I bend her leg.  Any genius ideas?  Or is it something that we put up with, cos I've seen it in lots of pants.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
vintorix ( ) posted Fri, 06 May 2011 at 6:30 AM
You should know by now, that the old-timers never answer important questions like this, while they love to answer beginners questions for some reason.. ;)
After you have used the AutoGroup Editor or OBJ2CR2 or whatever you use, open the OBJ in your preferred modeller and correct the grouping mistakes. There is no way in the world to avoid this. Then, to do the rigging you need the right donor file. 'Stylin for M4' works well for Michael. Usually there is no problem with V4 if the grouping is right.
Fugazi1968 ( ) posted Fri, 06 May 2011 at 6:40 AM
Thanks Vintorix, I appreciate the feedback.
I've tried a couple of different groupings for this so far, I think I will give it another go though.  The pants are for V4 so I shall just persist until it's down to as little distortion as possible.
John.
vintorix ( ) posted Fri, 06 May 2011 at 6:47 AM
How do you do the grouping? With your modelling program, in the grouping editor or AutoGroup Editor or what?
Fugazi1968 ( ) posted Fri, 06 May 2011 at 8:08 AM
I got autogroup editor to start me off, then adjusted the groups in AGE before exporting.
vintorix ( ) posted Fri, 06 May 2011 at 8:14 AM
That's making me very curious, as you seem to do everything right. I very much would like to have a look at that mesh allthough I understand if you don't want to.
Fugazi1968 ( ) posted Fri, 06 May 2011 at 8:23 AM
it may be that I have too much of a hip group between her legs, though I was getting the same issue when I had only 2 lines of polys down there (I have 4 now, which seemed to improve things).
I have also adjusted the inner mat sphere on her thigh a little, but again this only seems to have improved the situation.
It may be that I'm missing something of course :) which is why i asked the question.
When I get myself home I'll drop you a pm regarding the mesh, if thats ok.
John
vintorix ( ) posted Fri, 06 May 2011 at 8:31 AM
ok. I you solve the issue yourself it would be fine if you told the rest of us what it was! :)
