poser animations is a problem because of the speed of rendering.
A broadcast tv frame is 640 x 480 (more or less)
if rendering is 1 minute thats 5 hours per 10 seconds or 30 hours per minute
people have done cartoons and other short films. A few have done longer films.
The few I know of are not using POser but doing work in Blender, 3dsmax or lightwave and using renderfarms to speed things up.
try looking up "Tripping the rift"
step 1 is to hire a team of korean animators with render farms and all needed software. then yer ready. just give 'em the storyboard and check their work every few hours. they can use poser if ya tell 'em, but pre-poser-9 versions may have some probs with trans, refr, shadows, anime style and that. even with something as easy as still frames AFAIK.
Animation well here goes.
This is the link to my utube channel , I have a number of animations.
At present I am handicapped by render times , yesterday 5hours on a three line speech for James G2 figure however , my main project is a Tiger Hunter film 12 min it will take about 6 months to complete.
I have another which is Jim & Jesus being used for an educational trust.
I regard each mov as practise , it is a bit like learning to draw, as you progress improvements are made.
Being the animator producer production and editor is quite a task, but good fun.
We should open a Poser channel on utube or vimto.
I do my best and leave the rest.
http://youtu.be/uI5wL8wkt98
Attached Link: Tiradestudios
Gabe Sabloff did a very nice short credited as being done with Poser7 (listed at the end of the short)called "The Drop" under the movies
this is one of the best i have seen and many long time Poser users will recoginze a lot of the props and characters that were used
You might as well PAY attention, because you can't afford FREE speech
Hi poser itself will NEVER....repeat...NEVER be suitable for large scale Film quality
animation because is does not have a production quality render engine or animation tools.
Cheers
Quote - Hi poser itself will NEVER....repeat...NEVER be suitable for large scale Film quality
animation because is does not have a production quality render engine or animation tools.Cheers
This, and the nature and quality of content will probably never match that produced by higher end apps like max. Only a few artists creating content for Poser, ever came close to film level characters and modeling (IMO, Sanctum Arts GRIM being one of the few in recent memory).
Tirade studios makes some great animation with poser content, and good music and editing do make a big difference, but it doesn't come anywhere CLOSE to film quality animation made using max, maya, XSI, etc. No advanced particle effects, fluid-cloth-hair simulation lacking, good bokeh/DOF, you name it- all not there or even approaching film quality standards.
Just head over to CG talk/society, Blur studios, etc and see what is currently being produced for film. And the rate of the difference in quality is growing. Look at what is being done with Vray 2.
Poser, is what it is. An app designed mostly for the hobbist. To elevate it to industry level standards is going to take a HUGE investment of time and money. Why bother, when so many are so far ahead. Doesn't mean poser can't and shouldn't improve. You do have to keep things in perspective though, as to what you can realistically expect out of this app.
We made this awhile ago and were happy with the images we got.
http://www.youtube.com/user/Taylormadefilms#p/a/u/2/5iKBZowAkXM
Attached Link: Robert's YouTube Channel
I've been playing with animation in Poser for about a year now. There is nothing more vexing than having an idea in mind and trying to translate that into an animation. It's tedious, time-consuming work. I believe I'm getting better at it, but my six second animations often take 12 hours to render. If I find a mistake, I have to re-do all of that rendering, and thus, the process gets old quickly!However, it can be rather fun to make characters "come to life" when the animation is completed. Some of the examples listed in this thread are quite well done, and I will likely never get THAT good. It's ok, though. Most of us who use Poser do so as a hobby.
High quality? That depends on the perspective of the viewer. Why don't you give it a try and post your results here?
Thanks guyyys great . thanks fot the responses.
Since i aim for simplicity and i want to make thinks fast, i was interested in
------>Exodus 3 from the web site http://www.tiradestudios.com/movies.html
It looks great. Now my question is though,
how do they keep zooming into the still pictures while the characters are animated using crossfade type of e ffect. Did they seperate the character and the background picture in seperate layers?
"how do they keep zooming into the still pictures while the characters are animated using crossfade type of e ffect. Did they seperate the character and the background picture in seperate layers?"
Looks like layered renders to me, I usually render .png sequences as that preserves transparency. If you have multi-layered video editing then using the same image sequence at different opacity and slightly out of phase can create the time-blur effect used on some of the headshots in the clip you linked.
Part of that is called the kens burn effect
Oh yes, I'd love to see what Tebop can produce.
although Poser may not be suitable for large scale animation production after seeing animations on some of the cartoon networks Poser could do something suitable for these network tv animations after seeing stuff like "southpark", squidbillies, jonny quest, ect... you could do a presentable animation for tv because the quality bar is not set very high.
You'd be hard-pressed to do high-quality animation in Poser alone, but that said, most high-level animation uses a number of programs, not just one. I use Poser (with Daz figures) to edit bvh motion capture, and adjust & compose the animation, adding the hand gestures, applying lip sync (from Mimic) etc., then render in Cinema 4D. You can judge if it's getting me anywhere:
http://www.youtube.com/watch?v=UDq0_GOE0pc
Lots of other software gets involved, but I spend most of my time in Poser, animating. I think with the proper skills, one could do something decent using Poser in the process, that--while it wouldn't be a Pixar--I agree with Stallion that you might be able to make something good enough for television, or maybe some kind of online commercial product--at least, that's what I'm hoping, someday! ;-)
Quote - You'd be hard-pressed to do high-quality animation in Poser alone, but that said, most high-level animation uses a number of programs, not just one. I use Poser (with Daz figures) to edit bvh motion capture, and adjust & compose the animation, adding the hand gestures, applying lip sync (from Mimic) etc., then render in Cinema 4D. You can judge if it's getting me anywhere:
THAT is impressive! Beautifully done!
One of the best (and longest) poser animations I've ever had the pleasure to view. Outstanding work, considering the tools being used. In some ways, it reminds me of the old 70s star trek animated series.
Thanks! That link is to Part 4, the latest part (of 5, still being worked on.) You can actually see the evolution of my process if you watch all 4 parts (also on Youtube, see below) as I developed my skills and workflow, and the technology improved as well. The earlier parts were animated almost exclusively by hand, while Part 4 is almost exclusively mocapped, which I think really allows for much more realistic and dynamic motion, but even mocap isn't a magic bullet since there is always a lot of cleanup and adjusting to be done, and even within Part 4 I think you can see that I'm more familiar by the end of that part than at the beginning.
In any case, I think the tools are available to an independent animator or small team to do some really good work, and it keeps getting better. Plus, I think the Daz models look as good as many high-end models, and keep getting better, so it may not be long before we see pro-level work being done with off-the-shelf--even "hobby" software--like Poser.
Link to my Youtube channel (there's also a little animation I was just fooling with to try something more fantasy-based):
http://www.youtube.com/user/Auroratrek
Many of you guys practice poser and graphics alot. Great.
But do you ever hope to accomplish something great? I don't see alot of stuff coming out of you guys except for theory and still images.
Is there anyone here that uses Poser and has created high quality movies? if so , any links?
