Thu, Nov 14, 7:45 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Daz Elite figures- go figure
3dBim ( ) posted Wed, 11 May 2011 at 1:51 PM · edited Thu, 14 November 2024 at 7:40 AM
Hi :o)
The first question I have is regarding the choice of with AO/ with out AO...
what is AO?
I have been chooseing with, and damn; I am haveing problems with my renders :o(
I thought I had the rendering thing down, but; these elite figures have proven to be difficult.  I learn to use less lights, pull back on the green and push red lights, but geez...
I did check out the DAZ site and can find nothing about it.
So thanks for any info, and I will post if I find anything.
3dbim
PoserPro 2012
RHaseltine ( ) posted Wed, 11 May 2011 at 1:54 PM
AO = ambient occlusion, adjusting the lightness of the surface according to how well it is hidden from the light sources.
3dBim ( ) posted Wed, 11 May 2011 at 2:21 PM
Thanks RH :o)
It sounds like a good thing to have :o)
3dbim
PoserPro 2012
markschum ( ) posted Wed, 11 May 2011 at 2:35 PM
It can add a degree of realism , but does change slightly how a figure gets lit. If its loading with the figure it must have AO set in the materials. You can also load materials without ao , and set one (or more) lights to AO which will affect all materials in the scene.
WandW ( ) posted Wed, 11 May 2011 at 2:36 PM
If you are using IDL in P8 or PP2010 you don't want AO on in your shader...
3dBim ( ) posted Wed, 11 May 2011 at 3:04 PM
Woahhhhhhh!
Good tip, thank you; WandW :o)
I thought that these figures were made to take advantage of IDL and global lighting????
AND thank you; markschum :o)
I can not recall that I did set lights to AO,,,,,,ooops
:o( I feel like such a newb....
3dbim
PoserPro 2012
3dBim ( ) posted Wed, 11 May 2011 at 3:58 PM · edited Wed, 11 May 2011 at 4:05 PM
Hi :o)
K, I just did a render and it is typical of the problems that I have been getting...
3dbim
PoserPro 2012
RobynsVeil ( ) posted Wed, 11 May 2011 at 5:02 PM
You'll find that a lot of shaders with in-built kludges (okay, features) are going to render like butt in PP2010's IDL/GC. You might want to do a search on what do do about fixing that... Bagginsbill posts hold most of the answers on that score, you you might do a search on his name.
For example, that hair... Kozaburo? What do you have the transparency map Image gamma set to (click on the image_source name to see)... should be set to Custom Gamma value of 1.
Metaphor of Chooks
3dBim ( ) posted Wed, 11 May 2011 at 7:48 PM · edited Wed, 11 May 2011 at 7:50 PM
Hi Robyns Veil
You are so helpful :o)
The hair is Super bob.  It useually turns out well.  It looks crappy here because of the adjustments I had made to get a good render on the figure. I have got some good renders with  these elite, but;then this will happen and does not seem to go away regardless of what I do with the settings.
I will of course take your advice.
I will also try these with- out the AO get comfortable with it, and then apply the Baggins fix :o)
(I worked quite sometime on this morph and the poor thing looks like she's been beaten) :o(
THANK YOU :o)
3dbim
PoserPro 2012
RobynsVeil ( ) posted Wed, 11 May 2011 at 7:55 PM
Actually, BagginsBill has a brilliant skin shader specifically designed for those PP2010 users who wish to use GC and IDL. Look for any post by him and you'll find links in his signature.
Metaphor of Chooks
