Thu, Jan 9, 8:11 PM CST
Subject: runtime and libraries not found or created
chessmaster2001 ( ) posted Thu, 12 May 2011 at 11:21 AM · edited Wed, 24 July 2024 at 6:03 PM
i have p7. i have tried to install it to another hdd, the same hdd, changed settings for saving, etc. whichever method i use, p7 comes up with the same message. runtime or libraries cannot be found or created.
it will finally open to victor 2 and i can pose it, but nothing else. loading content from zips fails, as rt and libs are not found. what is happening?
it's really getting very frustrating and i'm noit very happy about it. suggestions or solutions needed. thanks.
LaurieA ( ) posted Thu, 12 May 2011 at 11:32 AM
There have been (literally) hundreds of threads on this. Do a search for "missing library" and you should come up with a bunch.
chessmaster2001 ( ) posted Thu, 12 May 2011 at 11:35 AM
thank you.
chessmaster2001 ( ) posted Thu, 12 May 2011 at 11:45 AM
nothing found concerning this problem. lots of posts showing work, but not a single one dealing with my problem.
bagginsbill ( ) posted Thu, 12 May 2011 at 12:10 PM
LibraryPrefs.xml contains the paths Poser thinks it is supposed to use. If the actual paths don't match what's in there, you will have to correct that.
ratscloset ( ) posted Fri, 13 May 2011 at 7:12 AM
Your OS and Version could have some bearing. If you still have troubles, contact Support (Put Attn: John in the Subject of the Incident)
ratscloset
aka John
JenX ( ) posted Fri, 13 May 2011 at 8:41 AM
Attached Link: http://www.renderosity.com/mod/rrwiki/index.php/Poser_8.0
For future reference, I just put this in the P8 FAQ on the Wiki (please excuse the mess, still editing)
chessmaster2001 ( ) posted Tue, 31 May 2011 at 7:36 AM
version p7 on win 7  x32 and x64 os' still will not work. put it on vista, seems to work okay. now all i have to do is figure out how to load different characters but it's in the doc file.
apparently p7 doesn't work on win 7 but for some unknown reason as every other program i have for xp/vista also works on win 7 32 and 64.
so other than win 7 os, i can just struggle along learning it.
issue seems to be resolved by using vista/xp.
LaurieA ( ) posted Tue, 31 May 2011 at 8:21 AM
Um, I have Poser 7 on my Windows 7 64bit system. Works fine.
bagginsbill ( ) posted Tue, 31 May 2011 at 8:44 AM
No more data = no more help from us.
What is the path you think is being used? What is in LibraryPrefs.xml? Do you have UAC turned on?
