Wed, Feb 5, 1:42 PM CST
Subject: Poser 6 renders better than Poser 7 with the same settings
ringer33609 ( ) posted Fri, 13 May 2011 at 7:15 PM · edited Tue, 04 February 2025 at 1:48 PM
I upgraded from P6 to P7 (OK, I'm a very late adopter) and am working on an Intel-based Mac.  Characters that render with crisp detail in P6, with the same render settings, have fuzzy detail in P7.  The link below shows the present render settings (of which I am aware) on both packages and the resulting renders with the same file.
http://www.flickr.com/photos/danziger
At full size it's clear, particularly in the hair, how much sharper the detail on the P6 render is than the P7 render.  P7 is easier to work with, so I'd really like not to have to go back.
How can I fix this?
Thanks
tebop ( ) posted Fri, 13 May 2011 at 7:59 PM
Well for me Poser 6 was better and is better than Poser 8. So i can see what you're saying.
You should try the newest poser. I dont know which one it is but i hear it's good.
LaurieA ( ) posted Fri, 13 May 2011 at 9:16 PM
Quote - Well for me Poser 6 was better and is better than Poser 8. So i can see what you're saying.
Poser8/Pro2010 ARE the newest versions. :/
tebop ( ) posted Fri, 13 May 2011 at 9:29 PM
Well if that's the case, i would go for Pro2010.
edgeverse ( ) posted Fri, 13 May 2011 at 10:16 PM
PoserPro2010 is great.
3D Digital Comics & Art/My homepage
http://www.edgeversemedia.com
markschum ( ) posted Fri, 13 May 2011 at 10:31 PM
did P6 have texture  filtering ?  its on the image map node in the material editor. The default setting in P7 can leave some things a bit fuzzy.
Try setting it to None and see if things improve.
Kalypso ( ) posted Sat, 14 May 2011 at 2:21 AM · edited Sat, 14 May 2011 at 2:22 AM
Site Admin Online Now!
Grab this nifty script by SVDL which will allow you to turn off texture filtering for everything and just turn it back on for transmapped hair.  (Poser 7 texture filtering utility)
http://www.renderosity.com/mod/freestuff/index.php?user_id=99327
Also, I don't recall if P7 gives you an option for the post filter size and type.   If so, set it to 3 and to 'sinc' not the default 'box'.   Here's a screencap of PP2010 settings but if it's in P7 it will be in the same location probably lower right.
http://www.renderosity.com/mod/forumpro/media/folder_10/file_467191.jpg
I find a combination of these two give crisper renders.
ringer33609 ( ) posted Sat, 14 May 2011 at 7:47 AM
Kalypso,
Turning off the filters brought my renders back to life.  Whoo-hoooo!
Thanks a million!
Kalypso ( ) posted Sat, 14 May 2011 at 8:11 AM
Glad it worked out but don't thank me, it's all svdl :)
