When Poser loads a figure, it separates all of the body parts into disconnected meshes. When you export the figure from Poser, it exports all of the individual mesh body parts if you don't choose the weld option. If you do choose the weld option, it does weld the parts back together, but leaves the extra vertices as extra vertices. Either way, you end up with the wrong number of vertices in the wrong order.
I don't know what Dazstudio wants, but this could be you problem. While there is a straightforward way to reorder the vertices to match the original obj file, I don't know of any commercial program that does so.
I can't get a full body OBJ exported from Poser Pro 2010 v.8.0.3.11916
I've tried importing it into dazstudio it says wrong # of vertices. I've triple checked and made sure i'm only exporting V4 and no extra props/ground. Is it just broken or am I doing something wrong? I can import just the 'head' part of V4 - but if i try to do 'load full body morph' or use Dazstudio's morph load pro, it won't load a FBM.
Any ideas?
