Sat, Feb 1, 8:22 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
Subject: toon shading
salmonfisher ( ) posted Fri, 27 May 2011 at 8:22 AM · edited Sat, 01 February 2025 at 8:22 PM
Is there a toon shader available to use on m4,v4 or the freak.
I would also like to be able to toon the ice pack, or clothing is this possible ?
3dvice ( ) posted Fri, 27 May 2011 at 9:06 AM
Have a look at the free toon shaders by jwebster45206
Le cinéma substitue à notre regard un monde qui s'accorde à nos désirs. - André Bazin
pakled ( ) posted Fri, 27 May 2011 at 10:51 AM
I think Trekigrrrl has one, for older versions...
salmonfisher ( ) posted Fri, 27 May 2011 at 11:15 AM
does anyone have a link to thee free toon shaders by jwebster45206
or Trekigrrrl
Thanks
bagginsbill ( ) posted Fri, 27 May 2011 at 11:23 AM · edited Fri, 27 May 2011 at 11:24 AM
For the billionth time. Search for the key shader word you want, author bagginsbill. i am on an airplane about to depart. otherwise i would find it for you
Winterclaw ( ) posted Fri, 27 May 2011 at 11:28 AM
Here's a thread where bill shares a shader.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Miss Nancy ( ) posted Fri, 27 May 2011 at 11:54 AM
use the edge-blend node to get the falloff shader for the lines.  the poser toon lines are lousy IMVHO.
salmonfisher ( ) posted Fri, 27 May 2011 at 11:57 AM
hmme i got the lltoon.mt5.txt, however what do i do with it.
Sorry im NEW
3dvice ( ) posted Fri, 27 May 2011 at 12:09 PM
Attached Link: jwebster
Here's the link to the jwebster45206 shaders: [Freestuff by jwebster45206](http://www.renderosity.com/mod/freestuff/index.php?user_id=407625)
You might want to have a look at his gallery too: Gallery jwebster
He posted some external links there beneath some of his images.
Winterclaw ( ) posted Fri, 27 May 2011 at 12:23 PM
salmon, first you delete the .txt from the name of the file.  .mtl is a material file.  You'll want to put it in your runtime under materials.  So poser - runtime - library - materials.
Then in the material room you can double click on the file to load it.
Now if you want to keep a preexisting texture file, you might want to use it with VSS instead.  Do a search on VSS for discussion on how to use it.
WARK!
3dvice ( ) posted Fri, 27 May 2011 at 12:25 PM
BTW, in Poser 7, there are toon shaders included: in Materials -> Cp Partners -> Sixus1 -> Toon
salmonfisher ( ) posted Fri, 27 May 2011 at 1:46 PM
Hi winterclaw so i have renamed the file to .mtl.
Can i copy it and paste it into the folder poser runtime - library - materials ?
Thanks also 3dvice i have poser 8 so i found the sixus1 >toon as well.
I also did a seach within renderosity toon free stuff I should have done this like ages ago, theres so much stuff.
I watched the quick tutorial on how to apply toon render: select body hold shift apply toon render i also did this to hair and clothing, it will be intresting to see if there is a improvement by using a toon shader.
Winterclaw ( ) posted Fri, 27 May 2011 at 2:26 PM
Yes copy and paste it there because it needs to be in the materials folder to select it in poser.
WARK!
salmonfisher ( ) posted Fri, 27 May 2011 at 2:34 PM
Thanks winterclaw just wanted to be sure before i tried doing it.
Is there such a thing as a body suit toon style ?
newbee question: how can i select the whole body and apply a shader effect.
I am having loads of fun trying out these effects.
Thanks
estherau ( ) posted Sat, 28 May 2011 at 8:34 AM
Attached Link: http://www.runtimedna.com/AdvShaders-Launcher-Art-Materials-Toon-plugin.html
I find the easiest way is to use olivier's toon shaders at runtimedna with the new shaderworks thing that semidieu has put out - a couple of clicks and instant tooning.
Lots of choices for whatever look you want with the semidieu option.  It's just so cool to use.  I love it. I asked poser makers to make a nonphotorealistic renderer but now I don't need them to do it (they were never going to anyway I don't think)
Love esther
MY ONLINE COMIC IS NOW LIVE
3dvice ( ) posted Sat, 28 May 2011 at 10:02 AM
Quote - newbee question: how can i select the whole body and apply a shader effect.
You can address  multiple materials in one go with a material collection (files with .mc6 or mz6 extension). You can create these on your own by clicking + "Add to Library", then choose "Material Collection" and "ok" to save or "Select Materials" first to specify which materials you want to save and the "ok" to save.
salmonfisher ( ) posted Sat, 28 May 2011 at 2:50 PM
i can not find the
Art Materials Vol1: Toon by Olivier
i searched no joy. Help!
salmonfisher ( ) posted Sat, 28 May 2011 at 3:30 PM
edit i found it by seaching through google: http://www.runtimedna.com/ArtMaterials/
I just can not afford it.
god i hate being unemployed anyway i saved the pyton script.
I will just have to manage with the toon shaders i got with poser 8.
Thanks everyone for your help
issue closed
estherau ( ) posted Sat, 28 May 2011 at 6:38 PM
oh they just had a sale on that recently.  maybe the toon shaders will go on sale again.  It is by far the easiest way, unless you are just making one of toon pics.  for me I'm trying to do 1000s of panels.
Love esther
