Sat, Feb 8, 8:55 PM CST
Subject: Mouse-Over Object ID?
Nyghtfall ( ) posted Sun, 29 May 2011 at 6:21 PM · edited Sat, 08 February 2025 at 8:44 PM
Is there a way to have Poser identify the name of an object when I mouse over it in the Preview window?
hborre ( ) posted Sun, 29 May 2011 at 6:45 PM
Online Now!
Nope.  You must select by clicking.
PhilC ( ) posted Sun, 29 May 2011 at 6:46 PM · edited Sun, 29 May 2011 at 6:47 PM
Yes, depending on your version, right click and it will pop up a select menu.
hborre ( ) posted Sun, 29 May 2011 at 7:05 PM
Online Now!
Phil, I think the OP means actually seeing an object name while mousing over.  Mousing over will definitely select the object or actor part by highlighting that area in white, however actually seeing an identification label popup will not happen unless you left- or right- click.
Nyghtfall ( ) posted Sun, 29 May 2011 at 8:00 PM
Quote - Phil, I think the OP means actually seeing an object name while mousing over.
Correct.
Quote - ... actually seeing an identification label popup will not happen unless you left- or right- click.
Thank you for clarifying.
