Sun, Dec 22, 5:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Subject: Object Visibility
CobraBlade ( ) posted Fri, 03 June 2011 at 7:01 AM · edited Sun, 22 December 2024 at 12:49 PM
Is there any way to get a primitive square to be invisible in a scene while also making everything behind it invisible too? So if this primitive covered half a scene for example, only half of it would render and the half covered would be invisible.
A pretty horrible description of what I'm after, I know. Truth be known, I don't know if such a thing is even possible in Poser.
Poser scripts by Snarlygribbly
Miss Nancy ( ) posted Fri, 03 June 2011 at 10:52 AM
my method would be to cut the render in half in APS, but maybe one of them can supply the node settings for bagginsbill's artistic lens that would prevent anything behind it from appearing in render.  the syntax of your request may be confusing, but bill created his lens (in part) for those who may not wish to do postwork in APS.
markschum ( ) posted Fri, 03 June 2011 at 11:45 AM
For that effect I render twice, putting what I want partly vidible on its own. Then load the two layers in a paint program , and delete part of the top layer.  You can do the same thing with more layers to get a mixed textured/wireframe effect.
CobraBlade ( ) posted Fri, 03 June 2011 at 6:55 PM
Thank you both for your suggestions, I'll give them both a try.
