Fri, Dec 27, 12:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Poser 7 mac Gradient Mode Where is it?
uncle808us ( ) posted Mon, 06 June 2011 at 2:11 PM · edited Thu, 26 December 2024 at 7:45 PM
I can't find the Poser 7 mac Gradient Mode.
MacBook Pro OSX El Capitan Ver 10.11.6
Miss Nancy ( ) posted Mon, 06 June 2011 at 2:15 PM
the gradient bump channel is often used with normal maps, not gradients.  bill has posted the node set-up to generate a photoshop-style gradient.
uncle808us ( ) posted Mon, 06 June 2011 at 2:19 PM
Yes I'm trying to use a normal map in Poser 7.
Miss Nancy ( ) posted Mon, 06 June 2011 at 2:20 PM · edited Mon, 06 June 2011 at 2:22 PM
then you gotta download or create some normal maps, but I dunno if they worked in poser 7.  they're like bump maps in that they use colours and they don't move the vertices at all.
uncle808us ( ) posted Mon, 06 June 2011 at 2:25 PM
I figured it out. I guess there is no Poser 7 mac Gradient Mode, but it worked.
Miss Nancy ( ) posted Mon, 06 June 2011 at 2:36 PM
yes, it may take a bum file, but it won't work in FFRender IIRC, whereas the normal maps work in FFRender (P8 and later).  there's some syntax problems between the use of the terms "channel", "mode" and "node".
Miss Nancy ( ) posted Mon, 06 June 2011 at 9:54 PM
oops, sorry for my earlier confusion. I see ya were referring to the mode channel. P7 didn't have it, and it could use bum files, and maybe normal maps, as P8 could use ddn (normal map) files which were plugged into the gradient bump channel, with the gradient bump mode selected.  apparently selecting the mode was redundant in P8, similar to the way the refract node worked in several channels other than the refract channel.
