Yep. Clear enough. You've encountered Gimbal Lock, where one axis occupies the same space as another. You can use the Direct Manipulation Tool to counteract this, or parent your object to a Primitive and rotate that.
Hello everybody,
I need to rotate an object first around it's Y-axis and then around the X-axis.
To my understanding, rotating around Y-axis corresponds to "twist" and rotating around X-axis corresponds to "bend".
I do rotations in the objects local coordinates and NOT in world coordinates.
My problem is that if I first "twist" then I need to rotate around the NEW rotated relative X-axis and NOT around the initial X-axis.
Hope my question is clear!
Thank you in advance,
Paul
