Sat, Jan 25, 2:04 PM CST
Subject: Problem loading V4 into Poser 8 after downloading it from Daz...
Bendinggrass ( ) posted Thu, 09 June 2011 at 4:19 PM · edited Sat, 25 January 2025 at 2:02 PM
Hi Folks.
I downloaded V4 (the basic) and then followed the directions for installing it into my PC.
I initialized it, and then went to Poser to play with it. It is nowhere in the Library. I then explored on my disc, and I see it is in Poser under People. Is that ok or should it be manually placed under or in another file?
Thanks.
Randy
markschum ( ) posted Thu, 09 June 2011 at 4:52 PM
it should be in ..RuntimeLibrariesCharacterDAZ People
I dont know if you have to do omething to refresh the P8 library.
hborre ( ) posted Thu, 09 June 2011 at 6:10 PM
Online Now!
If all your DAZ base models are placed into one runtime folder, they will appear under DAZ People as markschum mentioned.
Bendinggrass ( ) posted Thu, 09 June 2011 at 8:37 PM
Thanks to both of you.
I followed the instructions but I will now put it in the proper file manually if I can.
markschum ( ) posted Thu, 09 June 2011 at 10:35 PM
wait!
what folder did it go to ?
the Daz installers are pretty good about loading correctly if pointed to the right folder.
infinity10 ( ) posted Thu, 09 June 2011 at 10:59 PM
Whenever you re-organise your installed DAZ3D figure runtimes, please simply run the DAZ3D Figure Update batch file to update the location for the morphs to work.  Typically, this would be a shortcut placed on your windows OS desktop (I don't know bout Macs, sorry).
You may run into some local security issues if you let Windows 7 block executable files outside of the Program Files folder area.
Eternal Hobbyist
WandW ( ) posted Fri, 10 June 2011 at 7:17 AM
Hmm... I wonder if you have your Runtime in a different loacation than the Poser program (which I belieeve is the default setting in P8); the DAZ installer may have installed it  to the Poser program directory.
Make sure you install V4 and your other content where the base Poser content is stored; better yet, create a folder called V4 and install all of your V4 content to that folder.  Put in an empty text file called 'poser.exe' to fool the DAZ installer, or tell the DAZ installers to install for DAZ Studio.  After you've insttalled the content, you can add that directory to the Poser Library; just click the Add Library button (the folder with the running man) on the right side of the Library. and browse to the V4 folder you created.
Bendinggrass ( ) posted Fri, 10 June 2011 at 8:01 AM
Thanks, everyone. There is so much help here.
I tried to move the V4 material manually into the P8 runtime (Still don't know what a runtime is or why it is called that) and unfortunately when I opened P8 to look for Victoria in the Library I could find ONLY the material labelled Poser 8.
I suspect I will have to reinstall P8 again.
Yes, also noticed that the instructions for installing the V4 is to load it into P8... so it seems that dosen't work. I have to directly inticate that it should install the P8 runtime... is that right?
Thanks again... Just another happy day learning :)
Randy
RHaseltine ( ) posted Fri, 10 June 2011 at 8:31 AM
Where is your Poser 8 content (assuming you want V4 in with the rest of it - there's no reason you can't have a separate content library just for V4, or for any other division of content that makes sense to you)?
Bendinggrass ( ) posted Fri, 10 June 2011 at 2:01 PM
Well, my P8 content is in Poser, and I think that is the default place for it.
I didn't know I could put my Poser content (You mean my library?) anywhere else.
So how do you devise a separate content library for V4 stuff, and keep it connected to P8 for easy access, through the Library I assume.
Thanks.
Randy
RHaseltine ( ) posted Fri, 10 June 2011 at 2:58 PM · edited Fri, 10 June 2011 at 2:58 PM
Create a folder, ideally not in the Program Files folder, and then run the V4 installer and point it to that folder (you will probably need to pick DAZ Studio as the target application to avoid the check for poser.exe - it still installs the right files for Poser). Start Poser and in the library panel click the icon which shows a folder with a + sign on it - that will open a folder selection dialogue. Select the folder you created, and that you installed V4 to. To switch between libraries just click the library name next to Show library.
mackis3D ( ) posted Fri, 10 June 2011 at 6:56 PM · edited Fri, 10 June 2011 at 6:56 PM
The 'People' folder (as mentioned in the OP's starter comment) is usually in the DAZ runtime under content but as far as I remember the file there would be a Puppeteer Preset or something similar not the character. Do they have DS and Poser installers just for the V4 figure?
RHaseltine ( ) posted Sat, 11 June 2011 at 8:39 AM
Yes, the people folder would be DS presets - but if the initialisation step came up that implies that the base, Poser-format, files were installed.
Bendinggrass ( ) posted Sat, 11 June 2011 at 1:18 PM
Hi everyone.
I downloaded again - I am really really glad that thing is free - and picked the path directly to P8 runtime for installation. Installation and initialization told me it was fine... so I opened P8 and looked in the library... again, no V4, no item in Downloads.
I did a search and no V4.
I have tried so many different ways to do this... nothing works so far.
I haven't tried starting a new file because so far, I can't trust the steps I have already gone through.
RHaseltine ( ) posted Sat, 11 June 2011 at 2:07 PM
Don't keep downloading, just save the installers to your machine and you can run them (if needed) multiple times. Now, exactly which installers are you running? For Poser you need only the base, the one with dpc in the name. And exactly which folder are you installing to - it should be the folder that holds the Runtime folder, and if you are using Windows 7 or Vista it should not be in Program Files or Program Files (x86).
Acadia ( ) posted Sat, 11 June 2011 at 2:18 PM · edited Sat, 11 June 2011 at 2:19 PM
EDIT: Never mind! I didn't read the question correctly!  lol
Bendinggrass ( ) posted Sat, 11 June 2011 at 2:35 PM
First, I want to thank everyone for trying to help me through your information and posts. I sincerely, deeply, appreciate all you are trying to do for me... and, of course, I feel so stupid... honest.
So I will tell you what I did last... of course, I re-read all the posts, then as markschum stated, I installed and made sure it was along this path... RuntimeLibrariesCharacterDAZ People
There was no problem with the installation, and initialization tool place.
Then I opened P8 and the Library showed no indication of that download. There is no indication of anything new in the Library at all, no download or new character. I used "Explore" to search C drive for the material in P8, and the V4 material is there.
But it will not appear in the library, and so I cannot yet load it to use.
I know I have to be doing something wrong... I just can't figure what it is, even with all your help... some day I will laugh at this :)
Randy
Acadia ( ) posted Sat, 11 June 2011 at 3:03 PM · edited Sat, 11 June 2011 at 3:13 PM
Click the images for a larger view.
V4 is tricky to install. I think we all had problems. I know I sure did.
Here is a picture tutorial. I think you might be installing into the wrong folder (the actual runtime instead of the actual program folder itself). Which causes a runtime within a runtime.
Hope this helps.  Don't forget to do the initialization after installing.
Acadia ( ) posted Sat, 11 June 2011 at 3:04 PM
next step
next step
next step
Acadia ( ) posted Sat, 11 June 2011 at 3:04 PM · edited Sat, 11 June 2011 at 3:07 PM
next step.
Note that I've selected the Poser 6 directory.  You will select whatever version of Poser that you are using.  Not the Runtime, the actual folder containing the version name.
Then just click OK and proceed with the installation.
Acadia ( ) posted Sat, 11 June 2011 at 3:09 PM · edited Sat, 11 June 2011 at 3:12 PM
I chose Poser 6 so this is my path to find V4.
C:Program FilesCurious LabsPoser 6RuntimelibrariesCharacterDAZ People
If you are using Poser 8 yours will  be under
C:Program FilesSmith MicroPoser 8RuntimelibrariesCharacterDAZ People
WandW ( ) posted Sat, 11 June 2011 at 5:37 PM · edited Sat, 11 June 2011 at 5:38 PM
> Quote - Well, my P8 content is in Poser, and I think that is the default place for it.
Are you sure about that?  I tried reinstalling Poser 8, and the default location for the content is in the Shared Documents outside of the Poser directory.  There is also an option to install it in the "classic" location of the main Poser directory. (Screenshot attached)  I have it installed as the classic method, myself.
Check C:/Shared Documents first; If it's not at this location, try a search for the file Andy.crz
Bendinggrass ( ) posted Sat, 11 June 2011 at 7:26 PM
Hi Acadia.
I went through that very process when I installed V4 one time, using P8 of course.
I will check on that again.
Hi WandW.
I can't clearly remember, but I think I used "Poser Directory," the 3rd choice, as I thought that was probably the best to use as the "traditional" option would work in a most straight forward way... after all if it was "traditional" I thought it was what most used, had no problems, and such.
I am the only person using my computer, PC, with XP Professional os. What do you think? Did I use the best alternative for installing P8 ??
I suspect I might have to delete and reinstall P8... what do you think?
Thanks.
Randy
hborre ( ) posted Sat, 11 June 2011 at 7:34 PM
Online Now!
Now, the only thing missing from the OP is which OS is the Poser installation.  Vista and Windows 7 will prevent direct access to Program Files folder as a security measure.  Much of the information provided is still rather unclear or too convoluted to exactly determine what is actually happening.  Acadia provided a detailed step-by-step illustration for V4 installation which is, by far, as accurate as anyone could ask for.
Also, I would advise anyone installing any type of software application, read each step of the installation process.  This is not to be a no-brainer procedure, there are too many hidden steps which will elude you if you choose to rush the installation.  WandW's comment is a perfect example.
Bendinggrass ( ) posted Sat, 11 June 2011 at 7:57 PM
It is XP Professional os.
Acadia ( ) posted Sat, 11 June 2011 at 8:09 PM
Can you please go and manually find the directory for your Daz People folder?  Please don't do a search. I want you to go into your program folder and open folders. Once you are at the Daz People folder, please either make a screen capture and post it here. Please include the address bar.  Or you can copy the entire address including the drive letter from the address bar and post it here.
Bendinggrass ( ) posted Sat, 11 June 2011 at 8:43 PM
Acadia,
That path is:
Poser 8/Runtime/Libraries/Characters/Daz People
There is also a path from the same Libraries just indicated:
Libraries/!DAZ/Victoria 4
Yes, that is !DAZ, with a "!" in front of DAZ. Inside this is what appears to be the needed Victoria 4 file of 10 Mega Bites. But I can't get a link to that when I open P8 and go to the library. It shows nothing downloaded and no new figures.
Are there other files that load V4 in P8?
What is Victoria 4 Base Power Loader? Is that needed to load V4 through the Library?
Thanks again.
Randy
bagginsbill ( ) posted Sat, 11 June 2011 at 8:55 PM · edited Sat, 11 June 2011 at 8:59 PM
Randy - you didn't do as Acadia asked. This is like pulling teeth.
We're trying to do two things:
Verify your FULL path. You did not include starting from the drive letter.
Verify the CONTENTS - that you have the files we think you should have in that folder.
Bendinggrass ( ) posted Sat, 11 June 2011 at 8:57 PM
Sorry... it is C drive.
Bendinggrass ( ) posted Sat, 11 June 2011 at 8:58 PM
Sorry... I don't know how to do a screen capture.
And it is drive c.
bagginsbill ( ) posted Sat, 11 June 2011 at 9:00 PM · edited Sat, 11 June 2011 at 9:01 PM
Go back and look at my post. I added my screen. Does yours look like that?
We know it's C drive. We mean we want the full path, starting with C:, not some abbreviation.
My V4 runtime is
c:/User/Ted/Desktop/Ted/Runtimes/V4
Yours, of course, will not be in Ted's desktop because you're not me.
bagginsbill ( ) posted Sat, 11 June 2011 at 9:04 PM
And now how it appears in Poser.
Observe the matching path info.
Bendinggrass ( ) posted Sat, 11 June 2011 at 9:19 PM
Here is the path:
C:Program FilesSmith MicroPoser 8RuntimeLibraries!DAZVictoria 4
This (Victoria 4) then contains a load of items such as rHand.
No images appear in the opened P8 program.
There is another path, strangely:
C:Program FilesSmith MicroPoser 8RuntimeLibrariesCharacterDAZ PeopleRuntimelibraries!DAZVictoria 4
And this also leads to items such as rHand.
I suspect there is repetation, possibly because I installed V4 in a number of ways in my attempts to get it to show up in P8.
I will have to go now for work purposes.
I will return here tomorrow.
Sincere thanks to everyone.
bagginsbill ( ) posted Sat, 11 June 2011 at 9:22 PM
Now we see what you did wrong.
You told the Daz installer to install into C:Program FilesSmith MicroPoser 8RuntimeLibrariesCharacterDAZ People.
That was a mistake.
You must tell it to install into
You created a whole new runtime inside the existing runtime. It's like you grafted a whole copy of yourself onto your own foot.
Acadia ( ) posted Sat, 11 June 2011 at 11:47 PM · edited Sat, 11 June 2011 at 11:47 PM
@ bagginsbill
Bingo!
Thanks for addressing the fix bagginsbill :) hugs
Hopefully this gets Randy on his way to using V4 :)
@ Randy
The  !Daz folder you found at the following path, are injection files that poser uses.  Don't touch those!!!
As bagginsbill pointed out, you created a runtine inside a runtime. That's why you can't see the files inside Poser. Poser is looking in this path for the files:  C:Program FilesSmith MicroPoser 8RuntimeLibrariesCharacterDAZ People  and since they are not there, it can't show them.
You need to reinstall into the path that bagginsbill instructed you to install into.
Here is a link to a picture that may help you understand the various file formats in Poser and where they can be found.
http://www.daz3d.com/i/faq/index/index?id=94
estherau ( ) posted Sun, 12 June 2011 at 4:32 AM
I install Vr4 into an external runtime (I don't find it necessary for it to be in my main poser folder at all, i think it can be anywhere in poser 8 and above).  After you go to that little suitcase icon top right to add the runtime to your runtimes, it is then important sometimes to run the little round refresh semicircle arrow thingy for the folder to show up.
Love esther
MY ONLINE COMIC IS NOW LIVE
RHaseltine ( ) posted Sun, 12 June 2011 at 9:06 AM
Quote - I install Vr4 into an external runtime (I don't find it necessary for it to be in my main poser folder at all, i think it can be anywhere in poser 8 and above).
Actually Poser 7 SR3 and above - and even in earlier versions of P7 if you have the search behaviour set to "Shallow". Not sure if the original PoserPro counts as an "above", but it does with SR1.
Acadia ( ) posted Mon, 13 June 2011 at 3:08 PM
Randy, did you get it figured out?
Bendinggrass ( ) posted Wed, 15 June 2011 at 4:19 PM
Hello Everyone.
I am back again.
Thanks to everyone for your help and advice. Before I do anything I want to ask you if you think I should re-install P8 so as to eleminate the many incorrect paths in it now. And after that follow your recommendations.
Randy
estherau ( ) posted Wed, 15 June 2011 at 6:07 PM
I would try installing the V4 and if that doesn't work you can reinstall P8
WandW ( ) posted Thu, 16 June 2011 at 7:01 AM
If you have installed DAZ content in the wrong place, you can uninstall it if you hadn't unchecked the uninstaller tick box on installation.  Look in your Start> All  Programs menu for a DAZ folder, and the uninstallers will be there.  Then reinstall it in the location BB gave you...
Plutom ( ) posted Thu, 16 June 2011 at 7:22 AM · edited Thu, 16 June 2011 at 7:27 AM
Bendinggrass, what is your operating system? Is it XP, Vista, or that new one or Mac?
You need a person that has your operating system and has Poser 8 running just fine with no problems.  Jan
bagginsbill ( ) posted Thu, 16 June 2011 at 8:07 AM
Randy said he has a PC with XP Professional - he's the only user - and he installed P8 using Poser installer 3rd option - traditional - Program Files.
chriscox ( ) posted Thu, 16 June 2011 at 8:33 AM
Quote - Sorry... I don't know how to do a screen capture.
And it is drive c.
you can learn how by searching with google (www.google.com) using the words"screen capture xp". The first link is this: http://www.seoconsultants.com/windows/print-screen/ and its explains how to do a screen capture
Chris Cox
Bendinggrass ( ) posted Thu, 16 June 2011 at 8:39 AM
Thanks everyone. I apprecaite all of you so much.
You know, I am not terribly skilled with computers.
I write reports, send mail, and such, but this is certainly pushing my boundries as far as program and computer smarts go. So please be patient with me. Let me reread all you have written, look up things, and think about what you have said, so I can approach even a small degree of decent understanding.
Sincere Thanks.
Randy
Plutom ( ) posted Thu, 16 June 2011 at 8:53 AM
I missed that BB.
How to do a screen capture: Usually its this way, ensure that your favorite 2D program is up be it PSP or PS etc.  Then to get the screen shot:  your keyboard, upper right locate the key with the word PrtSc SysRq  then hold down shift key and press that key.  The screen shot is now loaded to your computer's clipboard, go to your favorite activated 2D program and  click on paste as new image (Im using PaintShop Pro so it may have different wording for your paint program).  Then crop, adjust etc to your heart's content. Jan
Plutom ( ) posted Thu, 16 June 2011 at 8:57 AM
Hi Randy, you will be before we are through with you--- Jan
