Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 4:00 pm)
Can you show me the setup of what you're trying to do? I don't want to go on a long explanation of why you're going about the lighting the wrong way unless you really are.
Are you doing indoor or outdoor? Day or night? Do you have objects in every direction (a room) or are substantial parts of the world empty? Which version of Poser are you using? Have you dealt with gamma properly? If P8 or PP 2010 are you using IDL correctly?
Also, if P8 or PP 2010 did you know that enabling tone mapping will do exactly what you're asking? I'm not suggesting you should do that, however, until I see what you are trying to do and why.
Hi Bagginsbill. I think i got around it. Attached is a cap of the shader. I probably forgot to attach the 2d map to the value node. So that as a matter of fact the entire map was enlighted by "5" which produced a pretty much white screen.
It is simply a screen that i want to enlighten the surrounding, ensure the walls are a little lighted from it...
http://www.renderosity.com/mod/rrfilelock/download.php?fileid=43961&key=9400>
3-D-Cs Facebook Page: 3-D-C on Facebook
Check the K-Azonica Story and World Evolving: K-Azonica
Check my website and products and the large freebie section: 3-D-C
THanks, will try this and post the difference
Sorry, me again, whats HSVTM ? I dont have Gain, do you mean the texture strenght?
Hi
sorry, i might should have mentioned that i need to work with onbaord materials as this is about a product for the market place so needs to work with standard settings. :)
So i guess the emulation of the above wouldnt work in a standard Poser 8 environment, would it?
Not directly an answer to your question, but works without too much render setting magic.
My question is why do you want to do this? It's not realistic. I just took several different photo exposures of my basement office monitors. The colors are blown out in all of the exposures where illumination of the surroundings is visible. When the exposure is set to show the monitors somewhat accurately, the rest of the room is pitch black.
ok... so that's real life... I don't think he would want real life, bb... :lol:
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Well I think millighost's trick is awesome.
In PP 2012 there are new options that can make invisible objects emit light!
one reason they do it is to get the actor's shot in the same frame with a reflection or projection of the screen, as in SO2001 and maybe other scifi or anime. OP can increase exposure (TM) but it will look fake. so these invisible posersurfaces would be like mill's hidden lite-emitting screen? wait, when was PP2010 released? 2009? .... checking ..... no, it was in 2010.
good idea, this trick with the two surfaces. sounds simple enought to be reproduced. i need something that would also work in DAZ, even if it is not emmitting light, but the new marketplace policies here would require me to have less poser shaders but more DAZ compatible stuff.
thanks all for your great input. I know the results arent always what real life would be, however, people want what they like, not what real life is :)
thanks again, for so much useable input!
I am really curious about any new version of Poser. 2010 pro was a real great step forward due to the IBL indirect lightning feature....
What marketplace are you talking about? Requiring products be dumbed down for DS is obnoxious.
Who is saying you have to have a single implementation that works the same in both?
ReRo does, we are required to submit at least an alternative non-shader mat set...
Oh- that's different that what you said earlier.
It's fine to require that it work in DS. What you said, though was "new marketplace policies here would require me to have less poser shaders". That's not true then, right? They don't REQUIRE you to have less poser shaders. They require you to have MORE than just poser shaders.
Yes, sorry for not expressing right, whats required is a material set that would work in both. Now, it is pretty clear that D/S standard wouldnt do indirect lightning anyway, neither would poser 7 or so. So i try to keep the shaders as simple as possible, so they would provide emmitting light when working with poser 8 up but would also work with DAZ in case some one uses DAZ.
So, the solution i am looking for was a smart one ;)
hope that explains. Sorry, this is not my first language.
Hi.
i wonder if anyone knows how i can make a material emmitting more light for enlighting the surrounding? I can move the value to up more than 1, ie 10. the enlightning seams good with that, however, the materials 2d texture is getting simply white then. so, i would wonder how i can keep the colortexture of the 2d pic, but still get much more light emmitted than what i get with an ambience setting of "1".
Any ideas?
thanks
