Tue, Feb 11, 12:31 AM CST
Subject: Black Spots
Arah ( ) posted Tue, 28 June 2011 at 2:54 PM · edited Tue, 11 February 2025 at 12:18 AM
i've been working on fixing the Elven princess gown, but while in poser i came across a strange problem. strange blacks spots all over the skirt. it looks awful in poser, but isn't even there is DS. any idea what it is?
LaurieA ( ) posted Tue, 28 June 2011 at 3:03 PM · edited Tue, 28 June 2011 at 3:08 PM
looks like a concave face or non-planar facet. Can you still see it when rendered?
Arah ( ) posted Tue, 28 June 2011 at 3:08 PM
Yes unfortunetly it's still there when i render it in poser.
markschum ( ) posted Tue, 28 June 2011 at 10:32 PM
try 'normals forward'    and then try turning shadows off for the dress. See what happens.
Winterclaw ( ) posted Tue, 28 June 2011 at 11:12 PM
You also have white spots.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Arah ( ) posted Wed, 29 June 2011 at 5:45 PM
Yes i have spots of both colors, how to i turn normals forward?
I made a new skirt, and that seemed to fix the problem, but it doesn't have such a nice UV map as the other. so i'd like to see if i can fix the problem, if not, oh well.
LaurieA ( ) posted Wed, 29 June 2011 at 5:55 PM
You do normals forward in the materials.
Arah ( ) posted Thu, 30 June 2011 at 4:08 PM
Thank you!
Arah ( ) posted Thu, 30 June 2011 at 4:34 PM
Hm tried it, but no luck. oh well, i'll just work with the other for now, thanks anyway!
nerd ( ) posted Fri, 01 July 2011 at 6:09 AM
Forum Moderator
Try turning the crease angle for that object waaaaay up, like 180. It looks like what's happening is some of the polys are getting creased while others are not.
Arah ( ) posted Fri, 01 July 2011 at 9:07 AM
How do i do that? sorry i'm not that firmilier with all the points of poser.
nerd ( ) posted Fri, 01 July 2011 at 10:38 AM
Forum Moderator
On the Object's Properties Tab there is an Crease Angle setting. The default value is 80. You can change the default value in prefrences. That would effect every thing new from that point forward.
Arah ( ) posted Fri, 01 July 2011 at 1:09 PM
Hm. No luck, thanks though.
vilters ( ) posted Fri, 01 July 2011 at 1:17 PM
Did you render?
Crease angle is only calculated at render time.
I would start by normals forward and crease angle at 180 and render.
You can set crease angle for every part in the parameters palette, or for the whole scene.
Goto General preferences, and set the crease angle there. 'default is always 80 but you can go to 180.
But from here, it looks more like a problem in the mesh.
Arah ( ) posted Fri, 01 July 2011 at 1:50 PM
Yeah i think it was the mesh, i made a new one, and it seemed to be ok, so i think it was just something in the old skirt. Thanks for all the help!
