Sat, Nov 9, 4:41 PM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Troubles in Oz....
Boni ( ) posted Sat, 02 July 2011 at 7:51 AM · edited Sat, 09 November 2024 at 4:38 PM
I was trying to enter a contest for Vue last month ... and after everything was said and done never finished in time and ... couldn't get the effect I was after.  I was trying to apply a texture to a path.  the yellow brick road from "The Wizard of Oz".  I used tiles, I used a brick wall ... and nothing worked.  I sure could use some help.  Even though the contest is over I still want to conquer this piece.  Thanks in advance.
Boni
Boni
bruno021 ( ) posted Sat, 02 July 2011 at 12:49 PM
How did you try getting that brickroad? Did you paint a path in the terrain editor?
Boni ( ) posted Sat, 02 July 2011 at 3:16 PM
The path was already there.  It was a scene I baught over at Cornucopia3d.  All I did was try to change the texture of the path itself from a gravel path to the brick.  I spent almost an entire month trying to get this.
Boni
redtrek ( ) posted Sat, 02 July 2011 at 9:47 PM
Here's an Oz image with a yellow brick texture applied to a terrain, using a black and white disdribution. Due to the anti-aliasing, it is difficult to see that the pattern continues in the same direction as the path makes its curves
redtrek ( ) posted Sun, 03 July 2011 at 3:26 AM
I did a quick test, since I've had this problem as well.  I used PSP to create a brick texture, applied the twirl warp brushes in the program, loaded the image as a terrain.  It's not perfect, but  with some work, could be a usable method to curve the Yellow Brick Road.
Boni ( ) posted Mon, 04 July 2011 at 8:35 AM
This is great ... but ... I'd like to just apply a texture to the path I already have and have the same effect, that the brick road follows the flow of the path.  Can that be done?
Boni
