Sat, Feb 15, 10:44 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 9:24 am)
Subject: Retopology
  • 1
  • 2
vintorix ( ) posted Thu, 07 July 2011 at 8:18 AM · edited Sat, 15 February 2025 at 10:41 AM
I have indeed at last found a way and a workflow that works, with C4D and the Mocca module with some scripts. Marvelous Designer will never be able to deliver a quadmesh, for the simple reason that no one else have. (delivered a good enough tri to quad conversion that is). So where is the people using retopology? After all it is a quite useful thing to have in your skill set not only for Marvelous Designer but also for cleaning up sculpting models and the like.
So how do you go about it? Is there a better way? Anyone tried Polyboost plugin for Max?
PhilC ( ) posted Thu, 07 July 2011 at 8:33 AM
Why the aversion to tri's? I grant you they do not look pretty but they work.
vintorix ( ) posted Thu, 07 July 2011 at 8:42 AM · edited Thu, 07 July 2011 at 8:45 AM
Phil, you will never be able to do advanced clothing with thickness, belt and borders, etc etc  without loop selections and the help you get from a nice clean quad mesh.
And why use a 3,5 MB zBrush model when a 20-30K optimized model looks just as good?
PhilC ( ) posted Thu, 07 July 2011 at 8:48 AM · edited Thu, 07 July 2011 at 8:49 AM
Good point. Yes if you want to do any additional editing I would agree with you.
ZBrush has a good retopology tool. I believe that you can also use it to get lower poly counts. I'd have to check to be sure, but I think it is controlable.
vintorix ( ) posted Thu, 07 July 2011 at 9:08 AM
Phil, I have no faith in the zBrush and retopology. The workflow is extremly convoluted and the Decimation Master produces uglier mesh than I hiertho though possible. I want only the most perfect mesh possible. With all due respect,(without your site I would never got started), what I am after is persons who do retopology on a regular basis!
ghonma ( ) posted Thu, 07 July 2011 at 9:10 AM
The best retop tool right now is Topogun, followed by 3DCoat...
vintorix ( ) posted Thu, 07 July 2011 at 9:28 AM · edited Thu, 07 July 2011 at 9:33 AM
Are you using any of these? (for retopology) I ask because I want only seasoned, regular users. I can also read forums and hearsay. Just for the record I have tried both Topogun and 3DCoat, (and zBrush too). But I have not tried Polyboost so if anyone has tried that I will be extremly interested.
Edit: I take it for granted that automatic conversion is not possible but a combination of tools and 'hands on'.
ghonma ( ) posted Thu, 07 July 2011 at 9:42 AM · edited Thu, 07 July 2011 at 9:44 AM
I use topogun, and have heard good things about 3DCoat, so I guess that bit's hearsay. I also use XSI's tools for hard surfaces where I need precision. XSI also has very good quadrangulation and decimation tools.
But if you've already tried all these out, why ask us what is good ? Use whichever one you like...
EDIT: Some degree of automation is possible and I believe 3DCoat actually allows you a lot of control over it's auto retop feature. I'd try a demo and see.
vintorix ( ) posted Thu, 07 July 2011 at 9:56 AM · edited Thu, 07 July 2011 at 9:58 AM
"But if you've already tried all these out, why ask us what is good ? Use whichever one you like..."
These are complex programs and it is only possible to make an accurate assessment of it after several hundred hours. I assume that I am not the only one who want to know the 'best' i e the fastest way to do it. Instead of each and every one of us spend days, weeks and months experimenting we can compare the time it takes to do a certain model we agree upon and arrive to some kind of conclusion.
Edit: One thing I know for sure and that is the 3DCoat's automatic retopology is utterly worthless.
PhilC ( ) posted Thu, 07 July 2011 at 10:03 AM
It will still be down to a personal opinion.
One may find the GUI "intuitive" another may find the same GUI unworkable.
vintorix ( ) posted Thu, 07 July 2011 at 10:14 AM · edited Thu, 07 July 2011 at 10:17 AM
I am of the belief that the 'personal opinion' is grossly overrated. Here is one MD tri model that want to be converted to quads with  marketplace quality. Do it, show the mesh and tell us how long time it took.
http://dl.dropbox.com/u/10255731/V4_jacket.zip
 Edit: And keep the UV map islands as in the original. (or as near as possible)
NanetteTredoux ( ) posted Thu, 07 July 2011 at 12:11 PM
I used Blender's retopo in version 2.49 and it worked fine. I haven't tried it with Blender 2.5 yet.
Poser 11 Pro, Windows 10
vintorix ( ) posted Thu, 07 July 2011 at 12:54 PM
Hi Nanette, Blender sounds interesting. What did you used it for? (The retopology I mean)
Paloth ( ) posted Thu, 07 July 2011 at 1:51 PM
I use 3d coat for retopology, to create usable figures with mid to low poly counts out of high-resolution Zbrush exports and voxel sculpts. I do this manually, “drawing” the new topology over the high-resolution models. It’s a comfortable process, but it takes time.
It may be unconventional, but I prefer to sculpt at high resolution during the creative process and establish workable topology after the fact.
I’m too busy working on my own stuff to offer my assistance with benchmarking but I wish you luck in your quest for an adequate retopology toolset.
vintorix ( ) posted Thu, 07 July 2011 at 2:44 PM · edited Thu, 07 July 2011 at 2:45 PM
Paloth, "It may be unconventional, but I prefer to sculpt at high resolution during the creative process and establish workable topology after the fact."
I don't now anything about it being unconventional or not but I am certain that you use the best way. And I agree when you say that it is a comfortable process.  Very relaxing, almost therapy! :) I understand that you are busy at the moment but could you make a educated guess over how long time it would take you to retopologize the model I posted?
Paloth ( ) posted Thu, 07 July 2011 at 3:01 PM
I'd give it an hour.
vintorix ( ) posted Thu, 07 July 2011 at 4:06 PM
Yes that is more or less what I am used to too. I did the model in 1,5 hour but I am sure I can get it down to one hour or a little less with more practice. So I don't have to change tools then. :)
Teyon ( ) posted Thu, 07 July 2011 at 8:35 PM · edited Thu, 07 July 2011 at 8:35 PM
Attached Link: http://www.topogun.com
I like Topogun for retopology. I recently used it for a mesh for work that I made. The head of the mesh started out as a sculpt from a sphere and then got retopod in Topogun and later continued to be modeled in Silo and Modo. Topogun is pretty fast and version 2's beta is shaping up nicely. If you're looking for a dedicated tool for retopology, few can beat it.
That said, Modo, Silo, Max, etc. all have the ability these days to do retopo work. It's a simple snap and constraint action, so it really depends on how well you know your tools and if you feel like including a new app for this one thing. Topogun has some additional features like texture swapping from the sculpt to the lower res model and other map generators that may make it worth a look to you. Otherwise, you may want to see if you can find a method in your current app that works.
vintorix ( ) posted Thu, 07 July 2011 at 9:13 PM · edited Thu, 07 July 2011 at 9:19 PM
Teyon, So how long do you estimate it would take to do the above piece of cloth in Topogun?
 Edit: The reason I think that a plugin to some of the industry standard programs like 3ds max, Maya or C4D (for example the new Polyboost for max) would be better is because you can use all the functionallity already in the high end application! (But I might be wrong)
Teyon ( ) posted Thu, 07 July 2011 at 9:57 PM
Not long but it depends on how many polys you want and the method you used. If you're using the new beta it would be less than 45 minutes...probably a half hour since it's primarily tube based. You could even get away with using symmetry in the new beta since it doesn't require 100% symmetry on the reference to work, which would cut the amount of time down. If you're using version 1, alot less is automated so you're probably looking at a full hour to maybe an hour and a half if you want to capture every wrinkle.
The beta of Topogun 2 has these nifty tube thingies...they remind me of loft curves in Rhino3D. They will conform to the mesh and will generate any number of polys you set to them. Once done, you can then build off them for the rest of the shirt. Alternatively, you could just paint the topology on top of the reference mesh and then bridge or manually combined polys to match up the various surfaces generated. All of this mentioned could be done in a few minutes. Now if you want to get more detailed in the topology generated, things will obviously slow down a tad but the surface itself is simplistic so there's little need. The only areas you'll probably want to do manually are the edges of the shirt and the collar. I really don't see it taking longer than 45 minutes and even that is longer than it probably would take.
Teyon ( ) posted Thu, 07 July 2011 at 10:00 PM
Attached Link: http://vimeo.com/topogun/videos
Have a look at the attached link. It shows videos of the features in the current beta for Topogun 2.0 - every user of Topogun 1 has access to the beta of 2 and will get 2.0 free. Not to be advertising or anything. It's just a pretty sweet deal I thought I would mention.
vintorix ( ) posted Fri, 08 July 2011 at 1:24 AM · edited Fri, 08 July 2011 at 1:27 AM
Teyon,
The price $100 for a single license sure is right. The last time I tried was version 1 so now you have convinced me to try the new version.
To be able to quickly make your own mesh of any model is good for your self-confidence! :)
Teyon ( ) posted Fri, 08 July 2011 at 2:28 AM
Cool! The features in the beta for version 2 is well worth the cost of version 1 - especially since you get to play with version 2 right now! :D Hope it goes well for ya.
kawecki ( ) posted Fri, 08 July 2011 at 3:13 AM
Attached Link: http://www.ShareCG.com/v/47408/view/11/Poser/PropViewer-3.2
If you want to convert triangles to quads or quads to triangles you use PropViewer and it does more things too. http://www.ShareCG.com/v/47408/view/11/Poser/PropViewer-3.2
Stupidity also evolves!
kawecki ( ) posted Fri, 08 July 2011 at 6:25 AM
file_470654.txt
> Quote - I am of the belief that the 'personal opinion' is grossly overrated. Here is one MD tri model that want to be converted to quads with  marketplace quality. Do it, show the mesh and tell us how long time it took. > > > >  Edit: And keep the UV map islands as in the original. (or as near as possible) > >   > >
Download PropViewer and convert it to quads, it converted the V4_jacket pretty well.
Remove the txt extension from the file
vintorix ( ) posted Fri, 08 July 2011 at 6:43 AM
I use Propviewer (mostly to take a quick look at a obj file). But if you study the quads done by Propviewer and compare it to the manual retop you will see why no one ever will succssed with automatic quadrilation.
kawecki ( ) posted Fri, 08 July 2011 at 7:04 AM
The mesh to the right was changed, it was decimated, simplified, some kind grid parameterization, Poisson ???, Laplace ???, (don't knw the correct names). PropViewer doesn't change the number of vertices and its position, neither UV. It only combines two triangles into a quad where is possible.
MeshLab has a lot of tools for editing and correcting meshes or scanned range data, sometimes crashes and the output is always a triangle mesh. This doesn't matter because once you have a regular grid of triangles in the way you want you can convert into quads using PropViewer
vintorix ( ) posted Fri, 08 July 2011 at 7:37 AM · edited Fri, 08 July 2011 at 7:49 AM
As I said in the beginning of the thread, you will never be able to do advanced clothing with thickness, belt and borders, etc etc without loop selections and the help you get from a nice clean quad mesh. It is not enough to combine two triangles into a quad it must be orderly.
"The mesh to the right was changed, it was decimated, simplified"
I you are going to work further with it keep it simple (KISS). In the end you can choose any level of subdivision you want and manipulate with magnets or brush or whatever. Are you working with conforming clothing?
"PropViewer doesn't change the number of vertices and its position"
So sad, because that is what I want.
Finaliy, UV map.
It is better to work piece by piece instead of taking on the whole mesh at once. An good work flow is to make selections of all the UV islands, and then retopoligize them one by one. So the UV maps are maintained.
kawecki ( ) posted Fri, 08 July 2011 at 8:40 AM · edited Fri, 08 July 2011 at 8:43 AM
Quote - "PropViewer doesn't change the number of vertices and its position"
You have requested a tri to quad converter and this what PropViewer does, but this is not you want. You need something to do remeshing as decimation, simplification, gridification, etc and not conversion of tris to quads. If the final mesh has trinagles or quads is the less important thing. In most cases all the quads will be converted to triangles at rendering time.
Quote - It is better to work piece by piece instead of taking on the whole mesh at once.
This is correct. Any mesh processing method will fail if your mesh is not two-manifold. In your jacket there is a button that will complicate all, you must sepparate the button from the cloth. Sepparate as two groups or slit into two meshes and process each group/mesh alone.
Some remeshing methods also requires that the mesh cannot intersect itself.
ghonma ( ) posted Fri, 08 July 2011 at 8:47 AM
Quote - It is better to work piece by piece instead of taking on the whole mesh at once. An good work flow is to make selections of all the UV islands, and then retopoligize them one by one. So the UV maps are maintained.
UVs should always be done after retop:
http://i54.tinypic.com/2md2zdl.jpg
DarkEdge ( ) posted Fri, 08 July 2011 at 8:48 AM
Attached Link: http://www.3d-coat.com/
I agree with you that Zbrush's topology is convoluted and difficult, too bad coming from such a great app. I've been using 3DCoat for the last 4 years and it's great. Very easy and quick, auto symmetry...best thing since sliced bread.
vintorix ( ) posted Fri, 08 July 2011 at 9:02 AM · edited Fri, 08 July 2011 at 9:16 AM
"You need something to do remeshing as decimation, simplification, gridification, etc and not conversion of tris to quads."
True, exactly so, to use as a BASE to build further upon. I thought that was obvious since we are in the Poser forum.
"If the final mesh has trinagles or quads is the less important thing"
NOT true, the mesh must be totally free from tris, ngons, concaves, collinears, degenerate facets of any form or shape whatsoever and be orderly (grid). Any vendor of conforming clothing free or commercial knows this.
Edit: If not these prerequists are fulfilled, it can be compared to building the house on a fondation of clay.
vintorix ( ) posted Fri, 08 July 2011 at 9:50 AM
"UVs should always be done after retop"
True, after every adorment, belt, pockets, harness, sholderpads, etc etc + subdivison and final tweaking of magnets and brushes are done. THEN you can do the UV map but if you have done what I suggested and all the selections are intact it can be done in 5 min.
ghonma ( ) posted Fri, 08 July 2011 at 10:06 AM
So post a pic of your retop's UVs then and we can compare...
vintorix ( ) posted Fri, 08 July 2011 at 10:57 AM
"So post a pic of your retop's UVs then and we can compare..."
Ok, here it is. The triangle version had UV map already when I posted it so what shall we compare?
Teyon ( ) posted Fri, 08 July 2011 at 11:28 AM · edited Fri, 08 July 2011 at 11:29 AM
Here's a thought - since it's a shirt, why not cut along the natural seams instead of making odd ones? It would probably lend itself better to the over all appearance once textured. Just my opinion though. Are you using a pelt mapping UV app or are you using basic UV functions like planar and that sort?
LaurieA ( ) posted Fri, 08 July 2011 at 11:31 AM
Is that your final UV map?
ghonma ( ) posted Fri, 08 July 2011 at 11:41 AM
No I mean put a basic texture on it so we can see how the retop version looks with the UVs it has. Because the mesh you posted earlier had serious problems with it's UVs, as can be seen here (click for bigger):
Cariad ( ) posted Fri, 08 July 2011 at 11:43 AM
I have nightmares when I see UV maps like that. Texturing becomes an exercise is torturous futility, well anything besides a basic colour fill.   Sorry, just call em as I see em.
vintorix ( ) posted Fri, 08 July 2011 at 11:45 AM
"Is that your final UV map?"
Laurie, I thought you had decided to be nice friday one day in the week?
This is just a scrap figure made for the discussion you may not have noticed but half the arm is gone..
Khai-J-Bach ( ) posted Fri, 08 July 2011 at 11:49 AM · edited Fri, 08 July 2011 at 11:50 AM
you never stated this was a scrap figure. (I checked back on your posts - remember we are not mind readers)
Cariad ( ) posted Fri, 08 July 2011 at 11:50 AM
Quote - "Is that your final UV map?"
Nice is overrated, honest is better.
Mind, had you mentioned that it was a scrap piece, people might be a little more understanding about obvious shortcomings.
But, still, for the 'scrap model' is that the final map?
LaurieA ( ) posted Fri, 08 July 2011 at 11:52 AM
Do I really have to be nice? Damn....
Cariad ( ) posted Fri, 08 July 2011 at 11:54 AM
Quote - Do I really have to be nice? Damn....
Nah. some of us love you for your periodically grumpy self.
vintorix ( ) posted Fri, 08 July 2011 at 11:56 AM
ghonma, "No I mean put a basic texture"
Ok I do it tommorow. Next time phrase your words more exactly!
I meant this discussion to general, about the best way to retop. Not about specific cloth items. If LaurieA (or anyone else) thinks she or he can make a better UV map let us make a challenge, meanwhile let's keep to business.
LaurieA ( ) posted Fri, 08 July 2011 at 11:56 AM
Quote - > Quote - Do I really have to be nice? Damn....
Awwww....
LOL
ghonma ( ) posted Fri, 08 July 2011 at 11:57 AM · edited Fri, 08 July 2011 at 12:02 PM
It's fine if it's a scrap figure, i'm more interested in how you got rid of the stretch artifacts in the original mesh (you can see them in the wavy lines in the check pattern) I got rid of them by redoing the UVs on the retop mesh, but if there's an easier/faster way, it would be useful to know...
EDIT: Fine, in careful phrasing then, you stated that you could get UVs on your retop mesh in 5 minutes by following your method. I'm interested in knowing what the method is and what the UVs you get this way (by which I mean a texture mapped on those UVs as well as the UV map atlas itself) look like. And then compare it with the workflow people usually follow, which is to do the UVs, from scratch, after retops.
Is that clearer now ?
vintorix ( ) posted Fri, 08 July 2011 at 12:05 PM
LaurieA, " had you mentioned that it was a scrap piece"
I should not have to mention that in a discussion. But if you want, I can download some of your free stuff and make a review..
LaurieA ( ) posted Fri, 08 July 2011 at 12:07 PM · edited Fri, 08 July 2011 at 12:08 PM
Quote - LaurieA, " had you mentioned that it was a scrap piece"
Er, that was not me that said that vintorix. Read again. I can understand how you thought it was me, but waddn't.
OH, and if you'd like to download my freebies and make a review feel free. I've never said my stuff was awesome or marketed it that way. But if you wanna be a jerk, go ahead.
Khai-J-Bach ( ) posted Fri, 08 July 2011 at 12:07 PM
ok everyone, we're mind readers since Vintorix does not want to simply make things easier for us by telling us things..
vintorix ( ) posted Fri, 08 July 2011 at 12:20 PM
LaurieA, "But if you wanna be a jerk, go ahead."
No it was not you who said it, my fault! :)
  • 1
  • 2
