I can't see much point in using Python as it would take as long to select and run the script as it does to click the display mode buttons or menu select the display mode.
You can set wireframe and line thickness in the Render>Preview tab if you want a stronger outline
Haha, Les Bentley just posted an image showing the setting tab whilst I was typing
Quote - I can't see much point in using Python as it would take as long to select and run the script as it does to click the display mode buttons or menu select the display mode.
OK, thanks. I need python because I need to render many images (>1600) so I need a script to do this for me.
Thanks,
Paul
In the "make movie" tab you can opt to render an image series rather than a movie, this works regardless of render settings. Besides using preview settings for testing movies I often render sequences in wireframe, silhouette, cartoon modes all as .png sequences (using png's preserves transparency) soi that they can be superimposed on other images
Hi all,
I have an object (a hand) and I need to render it with figure style outline .
I can view the hand as outline in the preview window but when I render all textures are loaded.
How can I render the image so as the final output will be just an outlined hand?
Thank you,
Paul
