Tue, Jan 21, 1:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Poser 7 8 wont start
goofygrape ( ) posted Sat, 16 July 2011 at 5:41 PM · edited Tue, 21 January 2025 at 1:35 PM
On my comp there is poser 6 7 8, 6 will start but 7 alway's says exe wont start or stoped working;8 will not do any thing just sit's and stares back at you dumb.
win 7 32 pro ,everthing used to work. All on a reinstall.
Any help or idea's will help
thank's
John
markschum ( ) posted Sat, 16 July 2011 at 5:52 PM
first did you install to the program files folder ?  for win 7 thats not a good option because of UAC.
did you right click on the poser.exe file and tell it to run as admin ? I had to do that for vista.
there are some other threads about where to install Poser for vista and Win 7.
Best seems to be to install it outside the program files folder where UAC wont get involved and to set the program rights to be Admin.
goofygrape ( ) posted Sat, 16 July 2011 at 6:37 PM
I will try that and it is in program files folder under smith micro.
thanks
hborre ( ) posted Sat, 16 July 2011 at 6:48 PM
Online Now!
UAC interference most likely, as markschum mentioned.  Isn't P7 under e-frontier?
icprncss2 ( ) posted Sun, 17 July 2011 at 12:17 PM
I've had issues with P7's exe on and off since the last SR.  Sometimes the only way to fix the issue is to back up your runtime, uninstall it and do a reinstall.
I think it has to do with the Poser 7 installing to the eFrontier folder in your folder tree and then the last SR changing short cut and some other registry entries so that Poser 7 shows up in the Smith Micro start menu folder rather than the eFrontiers.  This is the only Poser SR that does that.
Don't bother sending to SMS tech support about it.  You will get a polite response that they no longer offer tech support for Poser 7.
goofygrape ( ) posted Mon, 18 July 2011 at 2:39 PM
reinstalled in a different drive,so far so good thanks for the help
john
