Sat, Jan 11, 4:04 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: importing X Frog Trees and Plants C8
blueblott ( ) posted Sun, 17 July 2011 at 5:28 AM · edited Sat, 11 January 2025 at 12:41 PM
Hello,  I have been trying to get some of the above into C8 with little luck so far!
The obj loads fine. from the drop down menu load obj.
The textures ???
Typical folder from Xfrog consists of.
OBJ
MTL
TIFF.
I wanted to create a spot in the browser folders for additional trees and shrubs.but these are not Runtime files so dont seem to be able to add them?
Very grateful for any help....thanks for reading
Sueposer ( ) posted Sun, 17 July 2011 at 10:12 AM
If all those files are in the same folder it should work if you do file>import.
Then you can add the tree as an object under the browser object tab by dragging and dropping.
MarkBremmer ( ) posted Sun, 17 July 2011 at 11:44 AM · edited Sun, 17 July 2011 at 11:45 AM
Several of the older xFrog sets did not import well into Carrara. Something about how they were saved into .obj files - the .mtl file had a different directory address hard coded into it. So, for those sets, you simply have to manually rejoin the textures.
I have one set where that happened so, for each item, I saved them into an xFrog Browser directory within Carrara and can simply drag and drop them.
Mark
blueblott ( ) posted Mon, 18 July 2011 at 7:14 AM
Thanks for your advice will try as you suggest.
Cheers
