Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Attached Link: Lion Thread
The link to the Lion thread is...http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2831604
Poser 2010 • Poser 8 • MacPro Desktop • Quad-Core Intel Xeon • 10 GB • Snow Leopard • Windows XP
The only issue that I know of is related to Icons in the Library not displaying, but the Mouse Over still works, so you can figure out where you want to go...
The other issue is related to permissions and only affects Activation.
BEFORE launching your freshly-installed copy of Poser (Debut, Poser 8 or Pro 2010), browse into the root Library/Application Support folder and create a folder for your copy of Poser- 'Poser', 'Poser Pro', or 'Poser Debut'. You'll need to provide an admin password to do this.
Launch and serialize Poser normally- you won't be able to see the category icons in the library pane but the mouseover category names should work.
1a. If you have launched Poser and entered a serial number and are now seeing Poser crash on launch, the first thing to do is to open System Preferences, go to the General pane and turn off the 'launch to previous state' option.
2a. Now go create the 'Poser', 'Poser Pro' or 'Poser Debut' folder as described in (1) above
3a. Launch and serialize Poser
4a. Now if you like you can reactivate Lion's 'launch to previous state' option.
Anyone that encounters other issues, please contact Support with details. Put Attn: John, Lion Issue in the Subject.
Thanks
ratscloset
aka John
Quote - This is another drama - reason to skip Poser forever - who "tf" decided to program the content manager in an absolutely odd Adobe environment ? - such a crap - which breaks on a small operation system change - go learn Objective C
i just launched poser7 in lion (the first time i've launched it in about a year) and i CAN NOT believe how responsive the controls are- even on characters with face morphs with tens and tens of dials that made the poser 8 gui crawl. in fact all the glitches that made me upgrade to poser 8 seem to have been ironed out on apples side of things :-/
steepleton...
You mentioned both Poser 7 and Poser 8 in your post. I'm a little confused. Have you tried Poser 8 in Lion yet? I'm still debating whether or when to update from Snow Leopard.
Thanks for the info.
dkal
Quote - steepleton...
dkal
hi, dkal,
poser 8 runs pretty much as it did in snow lep, with the exception of some missing graphics in the library browser. i launched poser 7 to see if it worked too, and it did.
i like lion alot, but there's nothing you'd really miss if you decided to wait.
best
-ste
Quote - Does anyone know if there is a work around for the icons issue? It's really quite annoying. Also, does anyone know if Poser 9 has the same issue?
i couldn't fix it. though you can use the links, the library item icons won't regenerate either- it might be worth switching to the finder and searching/dragging in stuff into your scene from there. poser 9 does have a re-written library that works very nicely, and the whole interface runs much faster for me
Quote - I suppose it's worth spending the $130 to upgrade then...
maybe, but if you don't want to, it's absolutely possible to carry on using poser 8 using the finder to drag and drop items from your runtime library into a scene- you can even drop poses and morphs onto figures. actually if i'd known this before i'd have probably used this instead of the library anyway :D
Any Mac users installed Lion yet? Wondering about Poser 8 and Poser Pro 2010 compatibility.
