Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 3:46 am)
Someone posted the exact question to Microsoft, and this is their response:
"It seems that Poser 6 system requirements are Windows 2000/XP only.
Have you tried installing in Compatibility mode?
If that doesn't work then I suspect you have run into a dead end, and your only option is to upgrade to Poser 8"
I have P6, P7, and P8 installed on Windows7 64 bit PC with no problems.
cheers,
dr geep
P.S.
P6 is installed in the "Curious Labs" folder and
P7 and P8 are installed in the "Smith Micro" folder.
Both "Curious Labs" and "Smith Micro" folders
are located in the "Program Files (x86) folder.
cheers,
dr geep ... :o]
edited 10/5/2019
I have Poser 6,7,8 and Pro 2010 installed in Windows 7 Professional 64 Bit and they're all installed in Program Files and I haven't had a single peep of an error. All my runtimes are on a different drive but all my Python scripts are in the Program Files runtimes for all of them. UAC is of course, turned off because it's only for idiots.
Hi
Just to join in I have Poser 6 and 8 installed on Windows Home Premium 64 bit.
No problems.
Try installing it in something other then the default folder and run the install as administrator or try compatibility mode as XP service pack 2.
I have it installed on a completely different drive on my computer.
Mike
If you shoot a mime, do you need a silencer?
Hi
As a Windows 7 beta tester and computer geek, I recomend that you leave the UAC turned off, forever!!!
It does help keep newbies out of trouble but beyond that it's just a pain in the butt.
I would also recomend an app called Take Ownership that will let you access a lot of things that Widows 7 tries to block.
Mike
I tried to install poser 6 on windows 7 and it appears an error before the installation begins.What s wrong?
