Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
I believe it is to remove the section from Poser UI prefs_1024x768.xml or whichever screen size you use from C:Documents and SettingsOwnerApplication DataPoser 7
This bit.
<WidgetPrefs widget="contentRoomTab" left="300" top="10" bottom="24" right="385" collapsed="2" rect.left="812" rect.top="10" rect.right="897" rect.bottom="24" />
I would make a copy of the file before you try the deletion so you can restore it if something bad happens.
Sorry to disagree with ye ratscloset - I just had a MAJOR imporvement.
The load on the CPU as it loaded the content in the background was VERY noticable over my DSL and it made the start up hang aprox three times the normal time, it also caused small glitches while navigating around.
When I clicked on the tab the content was Already loaded.
After removing it, Poser 7 popped right open (after loading the splash screen and taking inventory and such) - at least three times faster. Once opened there are no more 'background glitches' as I navigate around the libraries and working space.
Perhaps You have no noticable change on your system, but not everyone is on Your system.
Does anyone remember the steps for removing Content Paradise from Poser 5 through 7?
I just reinstalled on a new machine and can not find my notes and Netherworks' link is no longer any good.
